How Many Keys?
Posted 28 May 2007 - 08:53 PM
Posted 28 May 2007 - 08:57 PM
Posted 28 May 2007 - 09:09 PM
Posted 28 May 2007 - 09:12 PM
Posted 29 May 2007 - 07:28 AM
Yes. Vaux will charge about £50 to have a new one cut and programmed.
Any idea on just a new key battery? How about just key reprogrammed? I have two keys but the 2nd does not work. It turns starter motor over but car won't start, orange light on stack is then lit when I start the car straight away with 'good' key (I think this is an immobiliser warning?).
So 'bad' 2nd key is probably incorrect transponder code or dead battery. Presumably this will be less than £50 but I have to remember we are talking about Vauxhall here
Posted 29 May 2007 - 06:40 PM
Edited by james141, 29 May 2007 - 06:41 PM.
Posted 29 May 2007 - 06:53 PM
If it is just the battery then it is just a standard battery, you can prise the alarm fob bit apart and put in two of the batterys on top of each other inside the little black plastic circle. Think they were about £1.50 each, or maybe that was for two.
Posted 29 May 2007 - 07:08 PM
The alarm plip is seperate to all that. It controls the Meta M99T alarm-module under the dash. The plip just activates and deactivates the alarm (and central-locking, if fitted).
You can buy new plips off of Ebay (as I did) but they won't work. Each M99T alarm unit has a 16 charactor hex-digit code. e.g. A34C56DBCD17596D programmed into the alarm box. The plip HAS to be programmed with this code or the alarm will ignore it. The code is given to the oroginal owner on a red platic card about the size of a business card. If you loose this 16-digit number (or never had it) and you lose the plips, then the alarm unit needs a back-to-factory reprogramme.
An Ebay purchased plip can be sent to a Meta dealer (such as http://www.abacuscaralarms.co.uk) who should programme the 16-digit code in for you for around £10.
You then have to folow this proceedure: -
Programming 16 digit Single Button Remotes
You will need one working remote to program a new remote into the system. This remote must be enabled by a dealer with a 16 digit code which is supplied on a plastic card, without this code the alarm brain will have to be sent back to be reprogrammed.
1 Arm and disarm the alarm sixteen times or until the alarm stops responding, alarm now in program mode.....
2 Once in program mode press the button of the new remotes(s), press the button of the original remote(s). This must be done within 8 seconds of each action. If 8 seconds pass without any actions the alarm will automatically exit programming mode and you will have to start from step 1.
3 Wait 8 seconds to exit learning mode.
4 Test remotes.
Hope this helps....
Steve
Posted 29 May 2007 - 07:26 PM
Posted 29 May 2007 - 07:47 PM
Posted 29 May 2007 - 07:55 PM
This card thing, I realized mine did not come with one a few months after getting the car. Went to Vauxhall dealer to get one it cost about £20 and a few days of security checks with Vauxhall. But the card I got does not have a 16 digit code on it?
It is a kind of laminated piece of card with no.s for key code with 5 digits, and Immobliser code with 4 digits.
Is there another card?
Im fairly sure there is another one for the alarm, the 16 digit code.
Without this code, from what I have read you cant get another key fob.
Posted 29 May 2007 - 07:57 PM
1. I'm not sure if they all do, but my own insurance company (Adrian Flux) would ask to see them if the car was stolen.
2. Yup. The plip is for the alarm (and central locking).
3. If you have one plip, then I would imagine that a Meta-alarm dealer can read it. Ring them and ask, and post their reply on here for future reference.
4. Yup. Keys are from Vauxhall, and only they have the programme codes for the new keys. The actual keys are around £50 and they all seem to charge different sums for programming them in. Gurneys of Newbury quoted me £45 just to programme and I've heard that others don't charge.
5. Vauxhall can deprogramme a key, but a stolen key will open doors and turn-off the steering-lock - but won't start the engine. You can deprogramme a plip from the alarm by using the reprogramme routine in my first mail with just the keys you have.
When I lost my bunch of keys together with my driving licence (with address) in my wallet it cost £1200 to change the locks on my house, the jaguar, and the VX! I was very sad
I wasn't allowed by the insurance company to take the jag on holiday - just in case whoever had my keys followed me on holiday and stole the car - it had to be stored at the Jaguar garage for three weeks whilst they waited for the new locks
Steve
Posted 29 May 2007 - 08:07 PM
Edited by james141, 29 May 2007 - 08:08 PM.
Posted 29 May 2007 - 08:10 PM
Posted 29 May 2007 - 08:20 PM
i had all that ''only peugeot can clone the transponder chip'' crap with my 106.. 75 quid for a new key..
went to parkers (local key cutting place) and 18 quid later i had a copy key programmed and it worked 100%...
Yeah this is what I am thinking, I might put the question to a decent key cutter round here to see what is said.
Posted 29 May 2007 - 08:44 PM
Posted 03 March 2008 - 01:01 PM
Posted 03 March 2008 - 01:23 PM
Edited by vxwanabee, 03 March 2008 - 01:26 PM.
Posted 03 March 2008 - 01:50 PM
Edited by covert ops, 03 March 2008 - 01:50 PM.
