Edited by ChazUwe, 04 June 2007 - 09:41 PM.
Video Camera And In Car Mounts
Posted 04 June 2007 - 09:39 PM
Posted 04 June 2007 - 09:52 PM
Depends what you want it for - if you're just planning on recording video in the car (rather than using it as a general-purpose camcorder that's occasionally in the car) you might do better with an Archos-type recorder combined with a bullet-cam.Can anyone recommend a good camcordered for use in the VX? Are there any particular types that are better suited to in car work?
I know nothing about the different types so any guidence or links to websites with good info would be much appreciated
edit: I guess they aren't really called Video Camcorders any more.... Showing my age there :S
The bullet-cams are significantly smaller and lighter than even the smallest camcorders, which gives you a lot more flexibility in mounting it - they're generally light enough that you can even mount them outside the car with just a bit of tape, and run the cable through the top of the window.
Posted 04 June 2007 - 10:10 PM
Don't know anything about this myself and this is not a recommendation. Got talking to David Smitheram, proprietor (according to his card) of Fast Films at the Castle Combe charity day. They had some good kit on display including bullet cams and various solid state and camera recording gear and multi-camera set ups. Didn't seem outrageously expensive. He was very approachable and happy to chat to me and the Mrs without any hard sell. We didn't buy anything!
There's some stuff in their shop at http://fastfilms.co....stallations.htm and if they didn't have what you want then I am sure he'd be happy to discuss your requirements.
Another favourite on here seems to be the Archos recorders - IIRC there's been some recent posts.
Steve
Edited by VIX, 04 June 2007 - 10:10 PM.
Posted 04 June 2007 - 10:13 PM
Edited by Guy182, 04 June 2007 - 10:33 PM.
Posted 05 June 2007 - 07:35 AM
Hague camera mounts
A bit pricey, very good piece of kit and used extensively when I had my Impreza...yet to be used with the VX (bullet cams weren't readily available/cheap when I bought it).
Posted 05 June 2007 - 07:51 AM
I have a Hague as well, but it's a right pain finding somewhere inside the VX to stick it - you're pretty much limited to the passenger side window, as the windscreen is too sloped to get the camera at a good angle, and if you stick it to the rear window it's either too high up or upside down!I have one of these
Hague camera mounts
Works fine outside the car, but it scares the wotsits off me to hang my DSLR+lens off it and drive around - although it's designed to allow that, and I have done it a few times. Wouldn't like to do it on track though!
Posted 05 June 2007 - 09:35 PM
Posted 06 June 2007 - 12:44 AM
http://www2.oregonsc...cid=77&pid=709#
Not expecting great things of it but hoping it will be alright in terms of quality. Seems to tick all the boxes for what I want, especially in terms of convenience.
Posted 06 June 2007 - 06:47 AM
Posted 06 June 2007 - 08:56 AM
Posted 06 June 2007 - 08:26 PM
http://www.motorspor...ex.php?cPath=30
Posted 06 June 2007 - 08:40 PM
Posted 11 June 2007 - 09:46 PM
Light weight, you could strap it to your helmet without it being a problem.
It's very easy to use, I had it working in under a minute.
The picture quality is reasonable, very important you need to get a fast 2GB SD card (found one on ebay for £9.99 with 150x speed) and I think this is what makes the biggest difference to picture quality. The sample videos shown on the manufacturers website are accurate to what I got in reality. Obviously its not TV quality or as good as a proper bullet cam rigged up to an archos etc. But as a quick and convenient way of catching your track action, without any need for cables or other equipment then its just the job - can also work as a supplement to your bullet cam.
I'm just off to find out good places to stick it, now where's the gaffer tape...
Posted 12 June 2007 - 07:42 AM
Posted 12 June 2007 - 04:47 PM
Link again to Hague site, brilliant service also
http://www.b-hague.c...cuum_mounts.htm
Thanks again for all the advice
Posted 12 June 2007 - 04:52 PM
Thats a bit rough jas - you gonna put a camcorder on that!Does the job, and cheap as chips :-
http://www.7dayshop....oducts_id=99648
