Remove Egr Valve?
16 replies to this topic
#1 n1k_ns
n1k_ns
  • 2,127 posts
  • Interests:Date Of VX First Registration: 01/03/2002
Posted 05 June 2007 - 11:28 AM
Hi,
I think ive hopefully sourced an EGR valve from a 2.2 vectra from a local scrappy, im going down there in a bit to pick it up, but can someone tell me how to remove the actual plug on top? Do you just pull it?
This is the best pic i could fine, ignore the blanking plate.
Help please :)
Thanks
N1K
#2 luna_s
luna_s
  • 1,934 posts
Posted 05 June 2007 - 11:32 AM
iirc you push down on the clip on the top, then it pulls clear been a while since i unplugged mine, but its pretty obvious once you startt tugging at it
#3 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 June 2007 - 12:52 PM
Hey! Thats my EGR! :) Yup, remove the grey safety clip first from the EGR socket & plug by pushing down on the centre prong and pushing out. Then remove the loom plug from the EGR. BTW my blanking plate has been in place for about 10k and no problems. I drilled a hole in the blanking plate allowing me to position the EGR as normal, allowing the plunger to operate.... you can see a slight indent where the plunger was hitting the plate, thats where I used a 12mm bit to drill a hole....! Steve
#4 rabidh
rabidh
  • 1,640 posts
Posted 05 June 2007 - 01:24 PM
If you look on z22se.co.uk there's a thread where vocky (who is also on here) is making EGR 'fakers' that mean you can remove the EGR valve completely...
#5 n1k_ns
n1k_ns
  • 2,127 posts
Posted 05 June 2007 - 02:45 PM
Ok guys, I got to the scrappy but it was the wrong goddam one!! Ive taken mine off and got it here infront of me, how would i go about 'cleaning' it for a temporary fix? :dry:
#6 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 June 2007 - 02:47 PM
Ok guys,
:dry:
Cleaning can sometimes do the trick! The carbon build up can prevent the unit functioning properly...
#7 n1k_ns
n1k_ns
  • 2,127 posts
Posted 05 June 2007 - 02:51 PM
I hope so, At the moment im just looking at the valve, with the 'plunger' up inside where/what/and with what do i clean? Help much appriciated :)
#8 Steve Crisp
Steve Crisp
  • 1,810 posts
  • Interests:VX220's...
Posted 05 June 2007 - 03:05 PM
Hi,
As Rabidh says, remove it. Vauxhall have decided that it is no longer required to meet the regulations, and is removing them on any car that comes into the workshop with a faulty EGR. Vocky's EGR gismo is a superb design.
The other course of action, is to take it to Vauxhall, who can deprogramme it from the ECU. and then blank it off. It shouldn't cost more than £50, should it?
Steve
#9 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 June 2007 - 03:24 PM
Removing it without an ECU update or a Vocky EGR Gismo will shut down fueling, if I remember correctly. Cleaning the unit is more or less the same procedure as this CLICKY
Edited by speedster, 05 June 2007 - 03:26 PM.
#10 Steve Crisp
Steve Crisp
  • 1,810 posts
Posted 05 June 2007 - 03:48 PM
I thought that's what I said Speedster - but it doesn't hurt to clarify :P It can only be removed after deprogramming it from the ECU, or by conecting the EGR-cheat from Vocky. Steve
#11 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 June 2007 - 04:59 PM
Steve
Sorry Steve... thumbsup
Am still dizzy after the weekend :D
Steve!
#12 n1k_ns
n1k_ns
  • 2,127 posts
Posted 05 June 2007 - 05:12 PM
oops! before i read that i just refitted the EGR with a small round plate over the hole and the car is now working :) im now expecting it to cut out..... :(
#13 n1k_ns
n1k_ns
  • 2,127 posts
Posted 05 June 2007 - 06:40 PM
Can anyone tell me if it will be okay to leave it as it is until i get a simulator? i have just placed a disc of thin aluminium over the hole between the gasket and the EGR valve. The actual 'plunger' bit is still free to move, the disc only covers the one hole. I just read above that if the EGR valve is removed the fuelling will shut down, but will this still happen if it still plugged in but just covered?? Please Help.... :blink:
#14 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 June 2007 - 07:03 PM
Only if you disconnect the EGR electrically. Your fine with the cover....
#15 n1k_ns
n1k_ns
  • 2,127 posts
Posted 05 June 2007 - 07:09 PM
Phew...thats a relief! Thanks mate, so shall i just expect to see the EML light come on? no other hidden problems? :dry: P.S - sorry for all the questionsn :rolleyes:
#16 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 05 June 2007 - 08:27 PM
Thanks mate,
:dry:
If you just blanked out one of the ports and if your cleaning was successful, no EML! thumbsup
#17 n1k_ns
n1k_ns
  • 2,127 posts
Posted 05 June 2007 - 08:41 PM
Cool! Ill have to wait and see if it comes on, hopefully not thumbsup
