Putting A Turbo Engine In An Na
Posted 25 June 2007 - 08:01 AM
Posted 25 June 2007 - 08:17 AM
Posted 25 June 2007 - 08:19 AM
Posted 25 June 2007 - 08:30 AM
Posted 25 June 2007 - 09:21 AM
Edited by danyeates, 25 June 2007 - 09:21 AM.
Posted 25 June 2007 - 10:15 AM
Posted 25 June 2007 - 10:20 AM
Posted 25 June 2007 - 11:02 AM
Theres not a huge amount of work involved [depending on what you consider as huge amount]
You know yourself once you start stripping the VX there's not much to them, if you have a donor car then the swap over is easy enough. Courtenays 'wording' makes it sound alot more technical than it actually is - ''turbo ducting for turbocharger cooling''.. wooowzer!! Although the cooling/air intake will be the main problem/issue - but your using a tubby clam with tubby ears so that will help.
I'd also look further afar than this site for gearbox, clutch etc info - alot of people on here seem to be narrow minded when it comes to conversions [unless so and so does it - it will never work kindda thing :rolleyes: ] If you have the time & patience & money anythings possible.
Posted 25 June 2007 - 11:30 AM
Posted 25 June 2007 - 03:51 PM
Posted 25 June 2007 - 04:02 PM
Posted 25 June 2007 - 10:22 PM
Have a look through the pics in this threadThe other thing I wanted to check was if the turbo ears will fit straight onto the NA with the turbo clam. I assume the sills are the same and it will fit.
