Supercharging
Posted 31 August 2007 - 01:10 AM
Posted 31 August 2007 - 03:36 AM
Posted 31 August 2007 - 06:27 AM
Posted 31 August 2007 - 07:24 AM
So if Theoretically speaking here....
If i supercharged my NA with courtenays stage 2, what could i do from there power wise? say with another £3k? as i'd quite like nearer 300bhp just for the stupidity factor...
The std con rod are only rated to go to 250bhp, so courtenay keep the std rev limit as this then tops out at about 245 bhp.
Stg 3 is on the cards but will require a stronger bottom end and prob decomp pistons.
Posted 31 August 2007 - 11:57 AM
The reason that the #4 piston melts around 280ish is the supercharger itself. Most of the ppl that have blown up were running under 2.7 pullies which is simply way out of the specs for max rpm on the blower. Also many were careless and didnt upgrade the heat exchanger which is a virtual must when going smaller than the stock pulley as well as not taking advantage of water injection. Also blower porting for Stagmier (sp?) helps out a ton with IATs. Its also been confirmed that the intake manifold is poorly designed and flows significantly more air to the #4. This is why from the factory and with GM stage 2 they are pig rich, its done to keep things safe. Most of the folks with blown engines were running 11:8 or higher on air fuel. Obviously your wideband is a collective reading of all 4 primaries so you never realize theres a problem with an individual cylinder. The problem can be corrected with a stand alone that allows for different fueling per cylinder. Sadly thats just not something you can do with HP tuners
Posted 31 August 2007 - 12:10 PM
Posted 31 August 2007 - 12:22 PM
will 300 bhp ever be achieved
A major problem with root's type SC's are they are only about 60% efficient compared to Centrifugal compressors so your always going have heat issues if you try running them up to high boost levels.
Oh and the reason that cylinder 4 gets the most flow is because the flow exits a roots blower at around 60 degrees to the vertical, and the compact design of the manifold and the laminova CC cores means it doen's get chance to even out before getting to the ports.
Posted 01 September 2007 - 09:43 AM
Posted 05 September 2007 - 02:30 AM
phonenix are starting development of there supercharger soon.. using a rotrex s/c
I'll be steering clear of that with a bargepole then. The reason being is a centrifugal supercharger is like a turbo but with a direct engine drive, they're old technology that was designed for engines like the WWII rolls royce merlin, As such they are really only efficient at high RPM and are designed to be held at a constant RPM.
Now if only someone will design one using a roots type supercharger
Posted 05 September 2007 - 07:50 AM
Mmmm. A pity that won't fit ....designed for engines like the WWII rolls royce merlin
Posted 05 September 2007 - 07:52 AM
Exactly why's that then?
The Rotrex have an epicyclic gearing system that acheives a high speed from a relatively low engine rotation speed. They are used on the Konigssegg and on some of the Honda R type SC conversions
And they are far more efficient than a roots or lysholm superchager, I should know they use our* Compressor Stages with the impeller modified to fit the gearing system.
* Cummins Turbo Technologies
Posted 05 September 2007 - 08:27 AM
have a look on the cobalt ss forums for what they do to the 2.2 in the US for fark all money...
for the cost of the courtenay conversion you could have a stand alone ecu, a baaad ass steel bottom end, suitable head and knock out about 300-350bhp no worries.
I'm slightly confused with the whole supercharging thing. I was under the impression on here that our engines used a supercharger in the States and so we could simply order bits and fit it to our 2.2.
Upon looking it up though, 2.0 Cobalt is supercharged rather than the 2.2 version. So do you mean people are retrofitting a different supercharger or the factory one?
I won't get into the 'whats the best supercharger' debate but just to let everyone know GM uses the M62 Eaton which i believe is a roots type?
Posted 05 September 2007 - 08:46 AM
Posted 05 September 2007 - 04:23 PM
The Rotrex .....
[/quote]
The Lysholm twin screw is also a very efficient supercharger. (Also internal compression, not like a Roots which needs a plenum to compress in.) In the US some people are already changing the standard 2,2 SC for more efficient Lysholm type twin screws...
Roots: up to 12-13 psi max, higher and it becomes very inefficient (= blowing hot air)
Higher => go twin screw. But this has internal compression and is therefore at partial load less efficient.
(With a simple valve the roots can shortcut the plenum to the inlet and so work with almost no load. Good for road cars...)
Posted 05 September 2007 - 07:06 PM
Posted 05 September 2007 - 09:53 PM
why not just wire in a hair dryer or garden vack...
superchargers are rubbish get a turbo
Hairdryer = centrifugal = turbo.....
Depends on what you want from your engine. High horsepower => go turbo
Throttle response => Nothing comes close to a well tuned NA engine with TB's. (= Expensive!)
A well done supercharger set-up is a good compromise i.m.o.
Edited by Exmantaa, 05 September 2007 - 09:53 PM.
Posted 05 September 2007 - 10:21 PM
Posted 05 September 2007 - 10:33 PM
Hi Guys sorry to interupt, and pardon my bad Swedish School English, but isn't it a fact that the 2,2 litre n/a engine has a comp of 9,5 kg compared to the american SC engine that has 8,5 kg.
If so I figure that either you will have to lower the comp or the S/C won't have any effect?
Then again lowering the comp means replacing the pistons, the rods or some sort of spacer plate.
Or I am completly wrong?
BR
Peter
Your right the 2 choices are puting 8.5 pistons in or using a double stack head gasket. ( as I have at the moment). I am in the process of a new build with 8.5 pistons and eagle bottom end and let Courtenays sort the rest out.
Posted 06 September 2007 - 07:07 AM
