Remove Pre-cat - Results?
15 replies to this topic
#1 YoungVXer
YoungVXer
  • 107 posts
  • Interests:stuff n that
Posted 20 September 2007 - 12:37 AM
Ive used search function but cant quite find what im looking for so maybe you lads can help! Seen recently in some posts about just removing the pre-cat? Is this right and what does it achieve with regards to just a standard exhuast set-up? Does it improve sound and bhp??? and what costs are involved as i wouldnt try this myself! If this isnt right what is a cost effective way to improve sound / bhp with regards to standard exhaust (without having to buy new ones?) Thanks , Dean
#2 NAP1
NAP1
  • 238 posts
Posted 20 September 2007 - 08:28 AM
I did search about precat removal and had to go back quite far historically where it was discussed quite alot. I am not sure it has an effect on sound unless you have an aftermarket exhaust (I may be wrong there) but it makes the engine breath much more freely. From the search I did general consensus is its a good mod to do - think its about 100 - 150 labour. If you want more sound I cant recomend an ITG airbox more as the sound is awesome but it is pricey, alternatively a K&N filter is pretty cheap and I think gives plenty of sound for your buck. Night be worth searching airbox mods as well as some people drill holes in the original box - not sure if this is any good though.
#3 trescoman
trescoman
  • 1,906 posts
  • Interests:Retirement ASAP, <br>Driving<br>Carp fishing<br>Football<br>kids
Posted 20 September 2007 - 08:32 AM
The DIY Car Care section is a good place to start looking, its at the top :P
<CLICKY>
Any thing that makes the car breath easier is gonna help with the BHP, especially if its a VXT
However unles you want the agro, you can get a front cat replacement part that will save the agro, both Courtenays and TMS (I think) do them
Have fun. :unsure:
Bob
Timbo airbox mod :P , never did my car any harm, other than changing the filter more often, which is never a bad thing anyway :rolleyes:
#4 RichH
RichH
  • 2,263 posts
Posted 20 September 2007 - 09:01 AM
When I removed mine on my old NA there was no change in the sound of the car. It did make the engine feel like it was breathing much more freely and therefore much smoother. I’d say it made the same sort of difference as having the TMS stg 1 remap done. The only way on the NA to get rid of it is to drill it out unfortunately, or replace the whole cat section. The NA doesn’t have a separate pre-cat pipe section like the VXT.
#5 drpau
drpau
  • 1,899 posts
Posted 20 September 2007 - 09:54 AM
Unlike RichH in my case after removing the precat there was a definate increase in db and it seemed more 'burbley' (standard backbox K&N filter). Definate improvement in pull. Do it yourself- put aside a fair few hours as the bolts can be a bitch.... I used 1 drill bit which snapped towards the end - you can pick up a load of cheap bits in wilkos though, I got shafted in B&Q - 7 quid for one!
Edited by drpau, 20 September 2007 - 09:55 AM.
#6 rabidh
rabidh
  • 1,640 posts
Posted 20 September 2007 - 11:54 AM
thumbsup On my NA I noticed the exhaust note got a bit more bass, i got more power *and* better fuel economy. Everything else was standard. It took me better part of a day to do myself (my car has done 60k miles and I had to cut off my exhaust bolts and replace them).
#7 RichH
RichH
  • 2,263 posts
Posted 20 September 2007 - 12:57 PM
I should perhaps add that it did have a VSE and a viper on already so perhaps any increase made from the pre-cat being removed was somewhat dwarfed by the rest of the bassiness and burbling from the other mods. If others have done it to a standard car then that would be a better guide. For saying that though, I can't believe it make a huge difference thumbsup
#8 YoungVXer
YoungVXer
  • 107 posts
Posted 20 September 2007 - 03:44 PM
Cheers for the replies lads, good help :D I do have a K&n already, so this may possibly increase sound slightly? :groupjump: When you say labour is £150 is that for them to do the same thing as the DIY job or would i have to give them a pre-cat replacement pipe for them to do? I dont really want to do this job myself as i really dont trust myself ....never worked on a car in my life (apart from fitting an air filter and replacing the header tank :P)
#9 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 20 September 2007 - 03:52 PM
i am about to do mine myself. if you are around cambridge area we could do a mini meet and see if anyone else wants to get theirs done too?
#10 robin
robin
  • 3,810 posts
Posted 20 September 2007 - 04:00 PM
just do it yourself its a easy job to do, i did mine by jacking back of car up and taking exhaust off took a bit of time but did it withno problems, then get the cat section and clamp it in a vice and drill the honeycomb bit out, worth getting a few drill bits as they heat up and melt. i did it with a large masonary bit with the hammer drill turned on went through quite nicely. worth doing i was runing a VSE so really made a lot of change in sound and smoother running.
#11 chris_uk
Posted 20 September 2007 - 04:01 PM
i can certainly back this up.. i have a VSE and in a tunnel... oh my god!
#12 JG
JG
  • 13,617 posts
Posted 20 September 2007 - 04:09 PM
I have done mine to 'protect' the manifold.
#13 YoungVXer
YoungVXer
  • 107 posts
Posted 20 September 2007 - 04:44 PM
Unfortunately im in North East m8. good shout tho thumbsup
#14 drpau
drpau
  • 1,899 posts
Posted 20 September 2007 - 04:54 PM
Give it a bash yourself mate - anything is possible if you are persistant. If after having a go you find you cant get the nuts off then you can think about taking it somewhere. Borrow some penetrating oil to free up the nuts from the manifold to precat. Borrow a dremel in case you cant get the exhaust bolts off :saw:, get a few drill bits and jobs a good un. thumbsup
#15 T5SOR
T5SOR
  • 174 posts
Posted 20 September 2007 - 06:10 PM
Is it worth knocking the cat out at the same time? De-pre cat sounds good. If im there maybe the cat should go aswell?? Mike
#16 Anarchy
Anarchy
  • 2,237 posts
Posted 20 September 2007 - 08:36 PM
I would not have a go unless your used to doing a bit of car DIY, something is likely to put a spanner in the works be it a seized bolt or having hard time drilling cat out. In theory its an easy job in practice no guarantees. Puts positve head back on... :) Its worth it tho, agree with comment above, better sound, similar BHP increse to Stage 1 remap.
