Avatar Help
9 replies to this topic
#1 stevevx220
stevevx220
  • 1,138 posts
  • Interests:Cars, Photography, Computers. cars :)
Posted 27 December 2002 - 06:37 PM
:D Hi, Does anyone know how to setup Avatars? Im getting nowhere very fast ;) Steve V.
#2 P11 COV
P11 COV
  • 7,686 posts
Posted 27 December 2002 - 06:51 PM
Me too! Come on, somebody out there help us technophobies!
#3 Guest_supergreen (Guest)
Posted 27 December 2002 - 07:16 PM
yep - click on 'My Controls' in the top menue, then on 'Edit Avatar Settings'. Then, you can choose wether a 'Pre-installed avatar' or 'your image avatar' (your own avatar), there you can even choose if you want to upload your avatar (if it is only available on your Harddisk) or you type the url (in case that the avatar ist somewhere online) - but just make shure that the image is in the range "Maximum Width = 64 pixels Maximum Height = 64 pixels)" hope that helps ? :D
#4 JonP
JonP
  • 169 posts
Posted 30 December 2002 - 10:58 AM
Just a test to see if I can post and the Avitar Works ;)
#5 P11 COV
P11 COV
  • 7,686 posts
Posted 30 December 2002 - 07:37 PM
Also testing
#6 P11 COV
P11 COV
  • 7,686 posts
Posted 30 December 2002 - 07:39 PM
and again
#7 P11 COV
P11 COV
  • 7,686 posts
Posted 30 December 2002 - 07:41 PM
Does anyone know why may avatar goes out of focus when the image is reduced to 64 by 64 pixels?
#8 Guest_TitaniumDan (Guest)
Posted 01 January 2003 - 01:44 PM
Its being altered in size, therefore pixellates when displayed. What you need to do is get the image you want, and define the size manually when you upload it - unless the actual image size is in fact 64x64 then it will get stretched/shrunk to size. For your Avatar, it looks like it should be shorter in height, so find out the correct size and enter the info in the Avatar settings. My Avatar, for example, is 64x50.
#9 Guest_Hugo Bruteseed (Guest)
Posted 02 January 2003 - 09:01 AM
Just dropped in to say what a brutal new forum this is. I may be back....
#10 iandhd
iandhd
  • 3,756 posts
Posted 28 January 2003 - 04:03 PM
testing avitar
