Attempted To Change Coolant Expansion Tank.....
12 replies to this topic
#1 calletson
calletson
  • 503 posts
  • Interests:Testing eyes<br />Cars<br />Women<br />Beer
Posted 02 December 2007 - 09:42 AM
Suprise suprise, vauxhall have given me the wrong coolant tank! The tank is identical, apart from the fact that it doesnt have a hole in the bottom for the sensor. Why doesnt it have this hole!!?? Any vx's that have the coolant sensor elsewere?? I only realised this after the brackets from the knackered coolant tank CRUMBLED when i took it off, the origional tank really is in a bad way! I darent touch it again in case it leaks! Now held on with gaffer tape.... thumbsdown
#2 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 02 December 2007 - 11:08 AM
Only one header tank listed for each model
Does the part number on yours tie up to these :blink:
#3 i need nos
i need nos
  • 3,404 posts
Posted 02 December 2007 - 11:27 AM
i got a new tank recently and it had a plug in the bottom you had to pull the old one out and plug it in the new one,
#4 calletson
calletson
  • 503 posts
Posted 02 December 2007 - 03:24 PM
The part number for the coolant tank matches the one it should be, but the bottom of the tank has no plug or even a marked area for cut out, its just smooth! 50 mile round trip to bring it back to vauxhall :angry: aswell!
#5 mandarinvx
mandarinvx
  • 12,621 posts
Posted 02 December 2007 - 07:51 PM
There isn't a hole into the tank as such, just a little protrusion in the plastic that the nib of the sensor fits into - the protrusion can be seen in the top picture of this thread thumbsup
#6 Whippet
Whippet
  • 648 posts
Posted 02 December 2007 - 09:46 PM
I'm sure the tubby and na tanks are different. When I took my VXT to Horizon they had an expansion tank but it was for the na and wouldn't fit...
#7 Alex Os
Alex Os
  • 155 posts
Posted 02 December 2007 - 10:22 PM
I'm almost positive that the N/A dosn't have a sensor in the expansion tank. The turbo certainly does though.
#8 mandarinvx
mandarinvx
  • 12,621 posts
Posted 03 December 2007 - 01:45 AM
Both of the tanks have level sensors, but I believe the tubby has an extra take off pipe Providing the part no. matches the correspoding no. in the link above it should be fine :huh:
#9 theotherhalf
theotherhalf
  • 249 posts
Posted 03 December 2007 - 07:43 AM
This is correct! :)
#10 calletson
calletson
  • 503 posts
Posted 03 December 2007 - 12:28 PM
Cant see the pic in the link yet as am at work and images won't load up!
There is nothing on the bottom of the new tank i bought, no protusions,indentations, holes, or orifices! Completely sealed! Vauxhall have ordered me a new one so will see what this is like when it comes!
#11 calletson
calletson
  • 503 posts
Posted 03 December 2007 - 06:29 PM
This is the new tank i bought, as you can see, nowere for the coolant sensor!
Imprinted on the side is a number: 90 530 690, doesnt match part number it should be...
#12 i need nos
i need nos
  • 3,404 posts
Posted 03 December 2007 - 06:32 PM
thats a first, maybe its a manufacturing fault or they put the wrong part number on the tank? u definately need one with a sensor hole in it though.
#13 calletson
calletson
  • 503 posts
Posted 03 December 2007 - 06:41 PM
I asked about this on the z22se forum and someone posted the following: "the expansion tank is actually from an astra 1.6 so they have supplied you with a LS model instead of a CDX model version it's basically the same but without the coolant level sensor fitting"
