Computer People...
Posted 03 March 2008 - 09:02 PM
Posted 03 March 2008 - 09:14 PM
For the last 2 weeks or so, my internet has been cutting off after exactly 10 minutes.
It won't re-connect until the computer has been restarted. We have been on the phone to Sky's 'technical helpline' about 5 times now, and we've still not had any luck. They're sending a new router out just in case.
It has always worked fine until recently. I have done a virus check, but it came up OK.
Is there a setting on the computer that could have been changed to make the internet keep disconnecting after 10 mins?
Any help gratefully received, as I'm rapidly loosing hair! Over to you….
Are you using a router or a modem that plugs in to the pc via usb?
SOunds like the latter, if that is the case you really should get a router, that will keep the connection to the internet 24x7 and will auto redial if it drops.
Posted 03 March 2008 - 09:17 PM
Edited by Colv, 03 March 2008 - 09:18 PM.
Posted 03 March 2008 - 09:43 PM
Thanks for the replies.
It's a wireless router, but plugged into the USB via an Ethernet adaptor, as the computer doesn't support wireless (so I'm told!).
Re the BT thing, it's worth checking out, although we have had broadband for about 3 years (6 months with Sky), so it's unlikely to be that causing the problem.
Posted 03 March 2008 - 09:47 PM
Those usb -> ethernet adapters are awful, that could be the problem, does your laptop no have an ethernet port you can use?
Have you looked in the logs on the router to see if it is actually the connection dropping out?
What model is the router?
Posted 03 March 2008 - 09:57 PM
It is a desktop PC, but unfortunately there is no Ethernet port, so the adaptor is a must. I'll get a new adaptor tomorrow, and see if that does the trick.
Re the logs, how would I check that? Sorry for being dim.
It's a Netgear router, but not sure of the exact model, as it doesn't seem to say on it. Again, how could i find this out?
Thanks again for the help.
Posted 03 March 2008 - 09:59 PM
Posted 03 March 2008 - 10:00 PM
I would get a network card rather than another adapter they can be bought for less than £10
The router should have a sticker on the bottom with a model number on it.
Do you know what the web address is to connect to the router? it is usually http://192.168.1.1 or http://192.168.0.1 or something similar, it should tell you in the manual or quick start guide
Posted 03 March 2008 - 10:10 PM
Having looked on the sticker, I believe the router is a Netgear 0681.
I'll try a network card then I reckon. Will that just plug into the USB too, or should it be installed inside the tower?
Re the logs, I got the details from the manual, and have C&P'd the latest logs in the post above. Does this give you any ideas?
Posted 03 March 2008 - 10:16 PM
Edited by james141, 03 March 2008 - 10:17 PM.
Posted 03 March 2008 - 10:20 PM
http://www.netgear.c...ter_dg834gt.php
If so what firmware version do you have, it should say on a status screen somewhere?
Posted 03 March 2008 - 10:23 PM
Right, hold off on the usb adapter and network card, it seems like a line problem.
Do you have filters on all the phone sockets in the house?
Are you using any telephone extension leads?
Can you get BT/Sky to test your line?
Could also be a faulty router.
We normally use an extension, but at present we have got it plugged into the main socket (Sky suggested this).
Only the phone, and internet are currently plugged in, via a filter.
Sky tested the line, and believe it to be OK.
There is a new router on the way, so I'll wait and see if this cures the problem.
Thanks for your help, and I'll keep my fingers crossed that the new router sorts the problem!
Posted 03 March 2008 - 10:25 PM
Is this the router you have?
It looks like that one.
The firmware version is: V1.02.28
Posted 03 March 2008 - 10:27 PM
Edited by Matt, 03 March 2008 - 10:29 PM.
Posted 03 March 2008 - 10:42 PM
Posted 03 March 2008 - 10:43 PM
Posted 03 March 2008 - 11:28 PM
Posted 03 March 2008 - 11:39 PM
Posted 04 March 2008 - 12:05 AM
http://www.google.co...G=Google Search
gives loads of results in a similar topic. The general consensus is you need a new network adaptor.
