Hi
My vx220 na exhaust co2 was high so i purchased a ELM323 CBD2 reader
Bank 1 02 sensor is reading 0.445 with the engine off and between 0.915-0.950 when running
Bank 2 O2 sesor reads ov with the engine off and 0.005v when running.
Anyone which if bank 2 is the is the front or rear before i order a new one off Flea bay.
Lambda Sensor
Started by
Lozz
, Mar 31 2008 06:47 PM
6 replies to this topic
Posted 31 March 2008 - 06:47 PM
Posted 31 March 2008 - 08:13 PM
bank 2 is after cat,
bank 1 on my car swings between 0.7 and 0.9 (mixture lambda)
Posted 02 April 2008 - 03:42 PM
There is no bank 2 on a 4 cylinder. Bank 2 would be the second row of cylinders on a V6 or V8 engine, which would have their own lambda sensors. You should only see Bank1 sensor 1 (pre cat) and Bank 1 sensor 2 (post cat).
Mark
Posted 02 April 2008 - 03:55 PM
oops my bad, must've been late
Posted 02 April 2008 - 05:55 PM
they are generally known as 'bank 1 - mixture' & 'bank 2 - post cat'
Posted 02 April 2008 - 07:06 PM
New rear lambda sensor arrived from ebayshop : vauxhallpartswarehouse
Just installed and seems to be working perfectly.
I'l have to update the software so i can log the voltage.
Not completely sure its cured all my problems as seems to be averaging out at about 0.8v
I"ll have to monitor my fuel consuption. might clean the spark plugs.
Posted 03 April 2008 - 09:08 AM
Depending on what software you have, can you clear engine codes on it. If so this should reset the learnt settings back to factory.
Then go out for a drive , ideally in 4th gear, and try and drive some nice partial throttle steadily at varying speeds, ie. not thrash it, and it should show in closed loop mode. You will see the short fuel trim voltage vary wildly from rich to lean, this is normal.
Keep an eye on your long term fuel trim to see if it goes + or - % as it learns your fuel / engine mods
I would be tempted to put the new lamda as the new mixture sensor, first, plus a clean fresh air filter, then go for the drive.
The second cat sensor is just to check cat efficiency .
