Lhd/rhd Conversion
Posted 03 April 2008 - 01:18 AM
Posted 03 April 2008 - 05:46 AM
Posted 03 April 2008 - 06:54 AM
I have spoken to an experienced Lotus Elise mechanic who thinks it should be possible but I have concerns regarding the bonded chasis and also I would not want to compromise the driving experience as a result of performimg the conversion.
No problem to convert.
The chassis is not 'handed' and all holes are present for both LHD and RHD.
It is not very cheap though. Often it's done for Elises imported from the UK to mainland europe because Elise prices are so much higher outside the UK it's an economic option.
What you would need to get new at least:
- Headlights
- rear lights
- dashboard top
- dash covers
- seat runners
- footwell divider
- steering rack
- heater
- center tunnel cover
Then work-wise you'd need to do:
- move battery
- move pedal box (labour-intensive!)
- move ABS unit, redo pipework
- move steering column
- move rear-view mirror
- re-shuffle wiring harness in dash
- move center tunnel/gearlever to other alternative postiion
and loads of little bits...
It's less involved than a conversion on a 'normal' car as most of the bits are basically 'bolt off - bolt on' (no cutting, etc.), so a converted car basically becomes no different from a 'native' LHD or RHD car.
It's just the part and labour cost that can make it un-interesting.
Posted 03 April 2008 - 10:36 PM
Posted 03 April 2008 - 10:47 PM
Posted 04 April 2008 - 05:25 AM
Don't you think it's possible to just swap over seat runners and that because "centre thingy with gear knob/handbrake" is central it works equally for both lhd and rhd??? Sorry if I'm being a bit stupid, but I haven't actually sat in my car for quite a while so exact layout is a bit of a blur!!!
Bigstep
I hava an OZ mate who wanted to do the same... gave up on the basis of cost.
Open comment: unless you own the car already, I would buy a RHD right off.
Even if you own the car now: I'd sell it and source a UK RHD. The lowest priced VX220's on the planet are in the UK. All LHD cars are much more expensive... (why??? No clue) As well, the GBP is SOOOOO low compared to other currencies that you will be better off financially.
Good luck
Posted 04 April 2008 - 05:54 AM
However, I don't think the local Holden market will be able to provide me with a lot of the parts you mention!! I knew I would need to get a new dash from the UK but I don't understand the need for new front/rear lights
If you get an LHD car from europe then the headlights will have the beam pattern reversed as for an RHD car. Difficult to modify.
Also the reverse light and the rear foglight will be on the wrong sides for an RHD car, so you need RHD light units.
: seat runners and centre tunnel.....I thought seats could just be swapped over and that central divider was just that, central and would be the same for lhd or rhd??
No.. The Elise/VX interior is not symmetrical. The driver gets more space than the passenger and the seats are angled in the car. Seat runners are therefore also different (mirrorred) between LHD and RHD.
The center footwell divider is also shaped differently on LHD vs. RHD cars because of the need for a foot-rest on the clutch side on the RHD car.
Posted 04 April 2008 - 06:16 AM
Posted 04 April 2008 - 07:30 AM
Posted 04 April 2008 - 04:13 PM
Posted 05 April 2008 - 10:40 PM
Posted 06 April 2008 - 08:10 AM
Posted 06 April 2008 - 08:21 AM
Posted 06 April 2008 - 10:38 AM
Posted 06 April 2008 - 01:05 PM
Thanks again Arno - I am printing out your advice and will take it with me to the mechanic here in Australia when trying to establish his price for the job. Getting those spare parts, I'm sure, will then be the big frustration.
First big step will be to get import approval in Australia.
make sure you get all the paperwork and import-approvals in Australia done BEFORE shipping the car over in a container.
They do not take it lightly if a car arrives in port and the right paperwork has not been done (crushing cars etc..)
Has the VX220/Speedster ever been sold in Australia? If not then it may need to be put through some sort of certification procedure before it's road-legal there.
Posted 07 April 2008 - 08:13 PM
