Fitting A Radio
Started by
k3vin
, Jan 21 2004 12:06 PM
8 replies to this topic
Posted 21 January 2004 - 12:06 PM
How easy is it to replace a radio in the VX? As it is all connecting wires together, how difficult can it be? Considering I haven't done this before, any advice welcome.
cheers
Kevin
Posted 21 January 2004 - 12:23 PM
Kevin
It is simple.
The wiring is all connected via the common standard 'ISO' connector, most radios of the last 5 years or so use these connectors.
On the back of the standard radio there is just 2 connector plugs (one is all the speaker wires, the other power & earth etc). just pull the 2 halves of the connector apart & the new radio should just plug straight in.
Even if you don't already have a radio in the car the VX comes with the wiring up to the female side of the ISO connectors, the new radio should have the mail side & plug straight in.
Regards
Chris
Edited by net_team1, 21 January 2004 - 12:23 PM.
Posted 21 January 2004 - 12:34 PM
& You'll need to buy a stereo removal tool from Halfords (or car stereo shop) that allows you to release the VDO unit.
cheers
Posted 21 January 2004 - 12:41 PM
cheers boys. Sounds simple.
For the removal tool, is it the same as using a spoon end to open a tin of paint?
Posted 21 January 2004 - 12:50 PM
Not reallyFor the removal tool, is it the same as using a spoon end to open a tin of paint?
Posted 21 January 2004 - 02:59 PM
Check all bits & pieces you got with car, they should supply the radio removal tools, mine were in the back of the folder with the service book & handbook in.
Chris
Posted 21 January 2004 - 05:37 PM
I used coat hangers, worked a treat, worthwhile changing the speakers, I put a MDLP sony mini disk, with a remote IR plipper, much better sound
Posted 22 January 2004 - 02:21 PM
I went for a minidisk too - my head unit (JVC) plays both CD's and minidisks, but all I use are the minidisks as they fit nicely into the small storage areas by the doors
If anybody (like me) ordered the car without a stereo then they probably haven't got a hole for one either. I ordered the replacement facia strip with the cutout in it - took about 8 weeks to arrive with lots of chasing up. Only cost about £50 and fitting was easy-ish. All the connectors/speakers are present with ISO connectors to just plug-and-play.
Must admit, you probably will need to change the speakers - it's my next job I think. There are probably other posts on this on the forum, but if anybody reads this then please add your recommendations.
Posted 22 January 2004 - 02:27 PM
Surely if your from Liverpoll you will have several differnt ways of removing a stereo in a matter of seconds. Granted you might not know how to put them back in.
Any tips on how to remove the VX alloys?
