Vx220 Pcd
Posted 24 January 2004 - 04:59 PM
Posted 24 January 2004 - 05:25 PM
Posted 25 January 2004 - 01:03 AM
Posted 25 January 2004 - 01:53 AM
Posted 25 January 2004 - 08:35 AM
Posted 25 January 2004 - 03:14 PM
In case anyone is in doubt http://www.metricati...ering/gears.htm defines this as follows (and a number of other related terms). There is an illustrative diagram at the link which did not import into this response.I think it stands for Pitch Circle Diameter - the diameter of the pitch circle, ie twice the distance from the axis to the pitch point.
Metric Gears
Metric gears are defined by the module system, as follows:
Module
The length in mm of the pitch circle diameter per tooth.
MOD = PCD / N
Number of Teeth
The number of teeth on the gear.
N = PCD / MOD
The diameter of the pitch circle.
PCD = N x MOD
Outside Diameter
The outside diameter of the gear.
OD = (N + 2) x MOD
Center Distance
The distance between the axes of two gears in mesh.
C = PCD(g) + PCD(p)
Circular Pitch
The distance between adjacent teeth measured along the arc at the pitch circle diameter.
CP = x MOD
Circular Tooth Thickness
The width of a tooth measured along the arc at the pitch circle diameter.
CTT = CP / 2
Addendum
The height of the tooth above the pitch circle diameter.
A = MOD
Dedendum
The depth of the tooth below the pitch circle diameter.
D = H - A
Whole Depth
The total depth of the space between adjacent teeth.
Finer than 1.25 MOD:
H = 2.4 x MOD
1.25 MOD and coarser:
H = 2.25 x MOD
Kind regards - Ian
Posted 25 January 2004 - 07:04 PM
Posted 25 January 2004 - 08:05 PM
PCD (Pitch Circle Diameter). To obtain this measurement (see diagram), draw a circle which passes through the centre of each wheel stud/bolt hole. Now draw a line from the centre of a wheel stud/bolt hole to the opposite side of the circle (crossing through the centre of the circle) - The distance of that line is the PCD (in mm).
Offset is also described on that page too
Scott.
Edited by nonterraquous, 25 January 2004 - 08:06 PM.
Posted 25 January 2004 - 08:15 PM
Posted 25 January 2004 - 08:28 PM
Posted 25 January 2004 - 09:11 PM
Posted 25 January 2004 - 09:15 PM
