Speedo Not Working, Abs Light On....
Posted 19 May 2008 - 10:36 PM
Posted 20 May 2008 - 04:52 AM
Posted 20 May 2008 - 07:52 AM
Posted 20 May 2008 - 09:56 AM
possible damaged wire to an abs sensor or the fuse has gone - that fuse also controls speedo
Try changing fuse 22, even if it looks ok - sometimes the blades corrode
Posted 20 May 2008 - 10:38 AM
Posted 20 May 2008 - 11:33 AM
Deffo sounds like the ABS fuse to me. If it were a sensor the speedo would still work.
so litterally a case of findinf and changing the blow fuse?
Posted 20 May 2008 - 11:36 AM
Posted 20 May 2008 - 11:40 AM
Posted 20 May 2008 - 11:51 AM
Just had my car fixed for this.
The wire on the sensor had rubbed thru on the damper, worth just taking the wheel off to check (rather than paying £120 for vaxhall to decide it wasn't warranty work (bit confused what is covered by the warranty tbh). - This was replaced (well spliced) and now working normally. Although ABS is now working so not all positive news...
Also as above check the fuse first - but it sounds like a break in the loom.
I'll try the fuse, which wheel are we talking about?
Thanks for all the replies guys
Edited by mark230, 20 May 2008 - 11:59 AM.
Posted 20 May 2008 - 02:16 PM
Posted 20 May 2008 - 04:15 PM
Edited by EdButler, 20 May 2008 - 04:15 PM.
Posted 20 May 2008 - 05:09 PM
Read post # 3 again!!
Nearside Left Rear wheel sensor also does the speedo
you forgot to say REAR in you 1st post.
Posted 20 May 2008 - 05:12 PM
99% will be the n/s/r sensor.
Posted 20 May 2008 - 06:52 PM
right will get on this tomorrow, also guy as i know you have a turbo on your hazards switch how many pins are there on the back?
Posted 20 May 2008 - 06:53 PM
Edited by Guy182, 20 May 2008 - 06:56 PM.
Posted 20 May 2008 - 06:58 PM
i'll go look for you now
edit - 7
Same as mine, i called auto vaux, they said tere was no diff between turbo ones and the na ones.. but you have confirmed they are wrong! i need another switch!
Posted 20 May 2008 - 06:59 PM
Posted 20 May 2008 - 07:06 PM
Edited by mark230, 20 May 2008 - 07:09 PM.
Posted 20 May 2008 - 07:32 PM
Oops, stand corrected! I meant too!
