Back Box Removal
Posted 22 May 2008 - 06:43 PM
Posted 22 May 2008 - 06:46 PM
Have my new Larini
however when i removed the rear undertray, it seamed as if the back box wouldnt fit past the cat, does the cat need to be removed from above the flexi section to get the back boc out? If so how have people got to the bolts above the flexi to get it off?
Any help much appreciated
I had this problem, some people say you can get it out but we couldnt, you need to remove most of the cat section if the bolts arnt siezed
We just took the clam off in the end
Posted 22 May 2008 - 06:50 PM
Posted 22 May 2008 - 06:54 PM
Posted 22 May 2008 - 07:03 PM
Posted 22 May 2008 - 07:06 PM
Posted 22 May 2008 - 09:56 PM
Posted 23 May 2008 - 06:10 AM
Posted 23 May 2008 - 09:10 AM
Posted 23 May 2008 - 10:14 AM
it's far easier to remove the downpipe than remove the clam
probably
Problem was when we did it we were half way through and we didnt have any spare bolts if we screwed them up and the car needed to be running by the time we finished.
So it was easier for us at the time to take the clam off, it is not as bad as everyone makes out with 2 people.
Posted 23 May 2008 - 11:19 AM
Posted 24 May 2008 - 06:23 PM
Posted 25 May 2008 - 08:25 AM
Posted 25 May 2008 - 09:33 AM
OK, been working on it today with the clam left on, pre-cat came away from the back box easy as, bolt just came straight off, just the hangers to release in the morning, any tips for the easiest way to do that, do you need to clamp the reverse of the bolts? Will the old back box fit past the pre-cat, rubber hanger removed, or willI need to relese the 3 bolts above the flexi section?
The old back box will fit past with the cat just dangling there - it is a bit of a squeeze and at first it may seen that there is no room - just mover it around a bit and if needs just flex the underneath of the clam - The exhaust hangers can be a pain to budge... just get physical on them. You'll need to cut a line through the heat shield to get it out
Still have a few useful pages bookmarked from when I did it
http://www.verboom.n...0511/index.html - bit more than just the back box but good pics
http://www.vx220.org...s...c=33673&hl=
http://www.vx220.org...s...7454&st=160 - shows a larini in place
Posted 25 May 2008 - 07:01 PM
Posted 25 May 2008 - 07:12 PM
