Edited by Shamone, 22 June 2008 - 08:55 AM.
Painting Subframe
Posted 22 June 2008 - 08:55 AM
Posted 22 June 2008 - 09:55 AM
Posted 22 June 2008 - 11:22 AM
Then cover with a heat proof paint
Is the rear subframe classed as part of the chassis - the vx comes with a ten yer warranty on chassis corrosion
Posted 22 June 2008 - 11:34 AM
Posted 22 June 2008 - 11:45 AM
I can check if you likeI was told that sand blasting the galvanised Subframe coating off saves over 2.5kg+ in weight too (so I've been told!)
Posted 22 June 2008 - 11:49 AM
Posted 22 June 2008 - 11:52 AM
Yes Please!
Posted 22 June 2008 - 12:11 PM
Thinking of going with epoxy mastic:
http://cgi.ebay.co.u...Q2em118Q2el1247
Posted 22 June 2008 - 12:48 PM
Posted 22 June 2008 - 08:22 PM
If you're applying straight onto the existing partially galvanized surface you'd be best using something like this first
the tvr boys, waxoil and then hammerite their rusty bits. maybe a slight variation could be a red-oxide primer and then hammerite.
i suspect the original galv would have been hot dipped but if you prepped the subframe and then galvafroided it it may be ok?
Posted 22 June 2008 - 08:25 PM
