I knew whatever route I took a standalone ecu would be required and a good one at that.
So after many, many months of working out what would be best I took the plunge and purchased a TMS / webcon throttle bodies kit
Fitting was quite easy, swapping the electronic throttle pedal to a cable operated throttle pedal being the major pita
I had removed the clam to install a Helix hybrid M32 clutch so this made the fitting much easier, but it can be done with the clam in place
I decided to completely remove the old ecu and associated wiring, this made some additional work but was worth the end result. This entailed reconnecting the oil pressure light switch, adding a seperate coolant temperature gauge, connecting the rev counter to the new ecu, connecting the dash eml light to the new ecu.
I decided to have the Alpha ecu mapped for my particular engine, this would not normally be necessary as the TMS kit comes already mapped to either a Stage 1 or Stage 3, but is a good idea if your engine spec doesn't fall into either of those groups
Well what can I say, the TMS throttle bodies have transformed the engines behaviour, it is now smooth and progressive, it behaves like a factory fresh car, it's such a joy to drive I've used two tanks of fuel over the weekend
Throttle bodies have to be the best mod I have fitted to the z22se engine, it sounds and goes like a sports car should
Edited by vocky, 07 July 2008 - 05:10 PM.
