Dump Valve Myth Busted
Posted 13 July 2008 - 09:10 PM
Posted 13 July 2008 - 10:40 PM
Posted 13 July 2008 - 11:06 PM
Posted 13 July 2008 - 11:11 PM
Posted 13 July 2008 - 11:46 PM
The unique sound caused by a blowoff valve (but not a compressor bypass valve) sometimes comes at a price. On a car where the blowoff valve is mounted after the mass airflow sensor, venting to atmosphere confuses the engine control unit (ECU) of the car. The ECU is told it has a specific amount of air in the intake system, and injects fuel accordingly. The amount of air released by the blowoff valve is not taken into consideration and the engine runs rich for a period of time. Engines with a manifold absolute pressure regulated ECU or where the blowoff is mounted upstream of the MAF sensor are not affected.
Typically this isn't a major issue, but sometimes it can lead to hesitation or stalling of the engine when the throttle is closed. This situation worsens with higher boost pressures. Eventually this can foul spark plugs and destroy the catalytic converter (when running rich, not all the fuel is properly burned in the cylinder which can allow unburned fuel to combust upon contact with and melt the converter or to cause incompletely combusted fuel to leave heavy carbon deposits).
One way to correct this problem is to reduce the boost going into your engine. This will cause the piston in the blow off valve to only open slightly. Another way to correct this problem would be to plumb the MAS after the BOV.
Taken from Wiki, so looks like it depends where it is positioned on the VXT
Posted 14 July 2008 - 12:14 AM
Posted 14 July 2008 - 08:04 AM
can I get one for my NA
I always just wind down my window and shout "SSSSSHHHHHHHHHHHHH!" everytime I change gear.
Posted 14 July 2008 - 08:09 AM
>>> Yes, but you have to have a Supercharger as well. <<<
(But it only costs £160 for the Supercharger and dump valve, so it's incredibly good value.)
Quality:
Posted 14 July 2008 - 08:11 AM
Posted 14 July 2008 - 08:48 AM
Posted 14 July 2008 - 09:02 AM
Posted 14 July 2008 - 09:19 AM
all this talk about dump valves "not working" sames to be a myth. i asked on here why no one has a dv fitted to there vx and was led to beleve that the car wound'nt run right.
well myth busted i fitted a dv to my car about 5 weeks ago and it is running spot on. iknow alot of vx owners dont like the sound and that is fine but i do and am glad i ignored the advice and fitted it.
dont get me wrong i do repect and rely on the info i get on this site but was just wondering how many people answer questions with info they have heard not what the have tested and know what works and what dosent
Well that's a convincing argument you've put across, I'm sold
Posted 14 July 2008 - 09:50 AM
hat are the rolling road results before and after?
Just curious on what gains you have seen, from fitting this so that you know it is working....
Posted 14 July 2008 - 10:09 AM
Posted 14 July 2008 - 10:49 AM
Posted 14 July 2008 - 11:02 AM
Posted 14 July 2008 - 11:26 AM
http://www.courtenay...?...oc&docId=65
re affecting AMM/running:
The dump valve for these engines must be a twin piston unit as the car has air mass metering. The twin piston unit stops the valve breathing un-metered air on vacuum, confusing the engine ECU.
Edited by cheeky_chops, 14 July 2008 - 11:28 AM.
