Na Alternator Belt Change Guide
10 replies to this topic
#1 petrolhead1
petrolhead1
  • 936 posts
  • Interests:Windsurfing and Sailing
    Karting
    My family
Posted 01 August 2008 - 01:52 PM
I'm hoping this is a relatively simple one but there doesn't appear to be a How To guide anywhere. So far without even having approached the car I imagine it would go something like this : 1. Jack up drivers side 2. Remove rear offside wheel 3. Remove wheel arch liner Anyone care to complete?
#2 Winstar
Winstar
  • 4,264 posts
Posted 01 August 2008 - 01:56 PM
4. Insert ratchet into square hole on tensioner arm 5. move arm to loosen belt and remove. 6. refit new belt
#3 petrolhead1
petrolhead1
  • 936 posts
    Karting
    My family
Posted 01 August 2008 - 02:55 PM
6. refit new belt
Wow! I think even I can tackle that!
Thank you
#4 petrolhead1
petrolhead1
  • 936 posts
    Karting
    My family
Posted 02 August 2008 - 09:31 PM
6. refit new belt
Thank you
Of course I didn't study this closely enough at the time.
Removed tensioner completely and then had to work out how to refit it. After that the purpose of the square hole in the tensioner made sense and finishing the job was a complete POP.
Then we really got bold and attacked the air box. Delved around and found the outboard mount had been taped together by some lazy arsed grease monkey. So took the opportunity to strip and clean the unit, modded the box with an extra hole. Sliced a chunk off the old internal trumpet and fitted that in the new hole. Now all I need to do is buy a new rubber mounting bracket and work out how to glue the new trumpet in and I can be the noisiest one in the car park again.
#5 Lps
Lps
    Team 600+
  • 3,375 posts
Posted 03 August 2008 - 01:31 AM
silicone sealent would probably be ideal for gluing the trumpet in the box
#6 Georgeralph43
Georgeralph43
  • 344 posts
Posted 10 July 2016 - 09:30 AM
Is it as easy to change the Alternator? Anyone know where I can get a new Bosch 0124425015 120Amp one?
#7 chris_uk
Posted 10 July 2016 - 09:38 AM
autovaux will probably do them.
#8 Georgeralph43
Georgeralph43
  • 344 posts
Posted 10 July 2016 - 02:48 PM
Weirdly not, can only find 100A ones.
#9 chris_uk
Posted 10 July 2016 - 02:59 PM
use that then.
#10 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 October 2016 - 09:10 AM
The belt is a 5pk880, eurocarparts sold me a 5pk1030 and I've just taken it off. Really don't want to put it back on, anyone know where I could get a 5pk880 belt from today?
#11 gaffer1986
gaffer1986
  • 4,408 posts
Posted 15 October 2016 - 09:17 AM
Got one, eurocarparts colchester have it.
