Posted 22 August 2008 - 12:06 PM
Posted 22 August 2008 - 12:22 PM
Posted 22 August 2008 - 01:26 PM
Posted 22 August 2008 - 04:19 PM
Posted 22 August 2008 - 04:26 PM
I'd like a boost gague but would like it mounted in a pod on the windscreen frame so that it is near line of sight, as mentioned above. After searching around, unfortuneately I don't think that such a pod exists for the VX.
Posted 22 August 2008 - 06:36 PM
Posted 23 August 2008 - 03:47 AM
I bought the saga electronic gauges from there , just boost and oil pressure and was hoping to mount them on top of dash pushed back to the windscreen was going to use something like the curved twin 60mm pods they use in the nissans and mitsi'sPaul
Have a look in www.autodials.co.uk thats where i got mine.
I went for the Smoky Blacker 60 mm bought 4 oil press, oil temp, boost, and volt fitting them had to use a sandwich plate for oil gauges onto the oil filter and turn the sensor in towards the sump.
Also the M20 npt fitting is no good you need a M18 if i remember.
Posted 23 August 2008 - 07:56 AM
Posted 23 August 2008 - 08:15 AM
Posted 23 August 2008 - 04:20 PM
Posted 23 August 2008 - 05:55 PM
Posted 24 August 2008 - 09:22 AM
The gauges i got were not that hard to hook up ran the cables inside the drives sill they sit in there nicely with CC pipe work did not need to drill anyholes.
I drilled 4 x 60mm hole into dash either side of the stack dials got the dash and dails trimmed in Alcantara if you cut the holes right the dials will slot in looking straight ahead if you know what i mean pop the little sun shades on and it all blends in with the stack dials which are back lit blue and not trimmed in alcantara.
What you have to take care with is if you use the sandwich plate the oil press sensor can be hit if in wrong position the best position is turned into wards sump but you will need to buy some npt fittings for that.
I guess a photo would explain better but dont know how to post them.
You get good instructions from autodials
Posted 24 August 2008 - 04:02 PM
Posted 24 August 2008 - 09:39 PM
Posted 25 August 2008 - 07:23 AM
Another option....top of steering column mounted alloy pod
Posted 25 August 2008 - 08:31 AM
Do you have this installed? Would be good to see some pics with it on the car.
Posted 27 August 2008 - 06:03 AM
