Plastic Sill Cover Removal
Started by
Mike-F
, Aug 30 2008 06:34 PM
5 replies to this topic
Posted 30 August 2008 - 06:34 PM
My drivers side sill cover has cracked and I need to remove it to do a repair. I did a search and the results seem to suggest that I just need to remove the two plastic screws and the on metal screw. I have done this but it shows no signs of coming off. I dont want to force it as i dont want any more cracks.
Mike
Posted 30 August 2008 - 06:39 PM
I think it's stuck down with some sort of tape
Posted 30 August 2008 - 06:45 PM
Edit.... make that 2 very wide strips of double sided tape.
Mike - I have a spare pas sill cover in the garage if you need a pic of the underneath to show the above.
Edited by Garry.L, 30 August 2008 - 06:53 PM.
Posted 30 August 2008 - 06:50 PM
..... stuck down with 2 strips of double-sided tape IIRC.
So just a case of carful levering?
Thanks
Posted 30 August 2008 - 06:54 PM
Thanks
Check my above edit.
Posted 30 August 2008 - 06:59 PM
Thanks
OK Garry / Manerinvx,
Thanks I will give it a go, tommow I might try warming it up with a hair drier to losen it up.
Thanks for the advice,
Mike.
