Adjusting The Boot And Door
Posted 01 September 2008 - 08:56 PM
Posted 01 September 2008 - 09:01 PM
On my new VX the boot lid sits slightly raised when closed (about 10mm). The boot lid is not fouling on anything, just seems that the catch i sitting too high. Has anyone had this problem and how is it adjusted?
My drivers door rattles a bit. There is some lateral movement in the hinge INSIDE the door. If I get the door cards off is the poing where door meets hinge visible/accessible for me to tighten things up? Could do with adjusting the windows a little whilst I'm at it I think.
Couple of other little questions if I may...
The 2.2NA has a cam chain rather than belt. An I correct in thinking that this does not need any attention until it starts to make a noise? (I'm fairly sure I read that on here somewhere but can no longer find the thread).
EGR... what is this?
Is a water ingress plate necessary for all VXs?
Is there a difinitive towing method!? Lots on contradictions on here!
Thanks chaps!
Hi
I had the same as you, i also found that the boot lid kept opening while driving along. To solve this i adjusted the latch on the lid untill it "clicked" into place nicley. After that i simply got a spanner (13mm i think) and pushed the spring up and turned the latch (its on a thread) now it closes and stays closed, is level with the body
Sam
Posted 01 September 2008 - 09:03 PM
Posted 01 September 2008 - 09:11 PM
Posted 01 September 2008 - 09:17 PM
Posted 01 September 2008 - 09:56 PM
Does a 52 plate class as a newer NA?
The boot does lock and cannot be pulled open (at least I don't want to pull any harder for fear of cracking it!).
I'll have a good fiddle with the boot and door when its light and dry!
How would I know if I had a water ingress issue? And by this time would it be an expensive fix? (wondering whether I should just get the ingress kit and fit it anyway).
Just ordered a coolant tank UV protective cover! Don't want that cracking.
Mine is an 02 and had the wrong oil jet fitted. Replaced the lot for peace of mind!
Dave
link
Edited by davestarck, 01 September 2008 - 10:01 PM.
Posted 01 September 2008 - 10:17 PM
Posted 02 September 2008 - 01:03 PM
mine is a 52 plate and my engine number is a fair way off the affected lot
Hopefully mine will be OK then too!
Does anyone have a link to this engine number/cam chain problem thread please? No amount of searching is giving a result!
Posted 02 September 2008 - 01:19 PM
How have you checked this?
Posted 02 September 2008 - 01:41 PM
Posted 02 September 2008 - 06:23 PM
Posted 05 September 2008 - 04:54 PM
