Rear Wheel Arch Liner Tear - Repair Or Replace
9 replies to this topic
#1 dw1
dw1
  • 3,043 posts
Posted 02 November 2008 - 12:30 AM
My rear, near side liner has a vertical split about 3 inches long just slightly forward of the centre of the wheel, starting at the bottom of the liner and working upwards. There is evidence of tyre shaped scuffing generally on the liner. I know a photo would help but I forgot to take one last time I had the wheel off and its peeing it down with rain this weekend so wont get a chance. Should I get a new wheel liner or is there something I can do to safely repair the split and give the liner better clearance of the wheel?
#2 mcewanslager
mcewanslager
  • 429 posts
Posted 02 November 2008 - 02:39 AM
deffinetley wouldn't bother with a new one until youve fixed the problem and even then only repair or replace if it would effect electrical components were the tear is.
#3 ianrm
ianrm
  • 11,097 posts
Posted 02 November 2008 - 09:35 AM
If you can repiar it do so. New ones are £80 ish :o
#4 dw1
dw1
  • 3,043 posts
Posted 03 November 2008 - 11:05 AM
How should it be repaired, i.e. what tools/materials are needed?
#5 aron916
aron916
  • 2,055 posts
Posted 03 November 2008 - 11:08 AM
Slightly off topic sorry, but any advice on re-fitting the liner? i just cannot get the 2 front screw fittings to go through the panel and the liner, cannot get the liner tight enough against the panel to get the fitting though both? Any tips? Thanks
#6 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 03 November 2008 - 02:04 PM
I have fixed them in the past and used any other inner wheel arch you can get your hands on cut the bit out needed and used stikaflex to bond. 4K later still fine ;)
I found cutting a section that has the same curve removes the need to have to hold it in place too long while it sets.
So
Stikaflex (black)
Inner wheel arch (any car is fine)
BIG scissors / hacksaw / stanley knife - which ever you prefer :D to do the cutting
24hrs to fully set
#7 danyeates
danyeates
  • 3,246 posts
Posted 03 November 2008 - 02:12 PM
When you come to buy it, it's called Sikaflex, not Stikaflex. Might help if you're searching on the internet. Used a lot in the boating industry.
#8 dw1
dw1
  • 3,043 posts
Posted 04 November 2008 - 10:55 AM
thumbsup thanks Danny
#9 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 04 November 2008 - 12:06 PM
Good point :D great stuff ;)
#10 simsy
simsy
  • 957 posts
    DOB is not real...
Posted 04 November 2008 - 12:22 PM
This reminds me of the top tips section in VIZ....
