Radiator Fan
10 replies to this topic
#1 Lozz
Lozz
  • 79 posts
Posted 18 November 2008 - 09:15 PM
My radiator fan seems to be permanently stuck on..... Any Idea's why the radiator fan would be stuck on? Any one Had this problem before? Is there a relay or switch hidden anywhere? Or even just a fuse i can pull out till i have time to have a good luck at it.
#2 SteveA
SteveA
  • 9,159 posts
Posted 18 November 2008 - 09:21 PM
Limp mode maybe?
#3 Lozz
Lozz
  • 79 posts
Posted 18 November 2008 - 09:44 PM
Could be. I'll Try plugging OBD11 reader in and see if anything comes up... I'll try resetting the ECU and checking the connections, Could be the rain. I'm sure i read something abour Fuse 8 for re-setting the ECU.
#4 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 18 November 2008 - 09:47 PM
Yep, fuse 8 for about 15 mins thumbsup
#5 techieboy
Posted 18 November 2008 - 09:53 PM
Err, why remove the fuse if you've got an OBDII reader? Surely better to use that to see the fault code and clear/reset anything showing and certainly much quicker?
#6 Lozz
Lozz
  • 79 posts
Posted 18 November 2008 - 09:56 PM
Be good to know what upset it..
#7 Garry.L
Garry.L
  • 1,920 posts
  • Interests:"Mammary Gland Enhancement"
Posted 18 November 2008 - 10:29 PM
Wouldn't this indicate some kind of coolant temp sensor fault?..... ie reading to hot thus kicking the rad fan in all the time.
#8 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 18 November 2008 - 10:36 PM
I had this problem. It was the coolant temp sensor.. a sub-£10 part.. :)
#9 Lozz
Lozz
  • 79 posts
Posted 19 November 2008 - 09:11 PM
Just read the Ecu The Ecu had an error code P0134, Which normally suggests that lambda 1 is reading high voltage... On intial inspection the voltage looked fine. coolant temp sensor also seems to be fine. I cleared the code and the fan has now now stopped so looks like it was in limp mode. Guess i'll just have to keep an eye on the lambda sensor. Thanks for your help i nver would have guessed it was in limp mode.
#10 techieboy
Posted 19 November 2008 - 09:16 PM
The fan permanently on is some form of failsafe or mini-limp mode. If you were in the real limp mode, you'd have known about it as the car really does limp as the power is totally cut and not pleasant when it happens in the fast lane of a motorway. :(
#11 SteveA
SteveA
  • 9,159 posts
Posted 19 November 2008 - 10:37 PM
No probs thumbsup
