Lambda Sensor Replacement
14 replies to this topic
#1 Oli
Oli
  • 250 posts
Posted 24 November 2008 - 02:17 PM
Ok so i got my car diagnostics done today and it shows error code P0130 Heated oxygen sensor bank 1 sensor 1. I presume i need to replace the lambda sensor before the cat?? Is it easy to replace? are there any guides? do you need to remove the undertray?? cheers for your help. oli
#2 chris_uk
Posted 24 November 2008 - 02:31 PM
u will have to remove the rear undertray, not sure which it it, but they come out quite easy or mine did anyway, and its 2001
#3 Oli
Oli
  • 250 posts
Posted 24 November 2008 - 02:48 PM
Ive got a price of 45.56 plus vat for a NGK lambda sensor. is it a good price?
#4 chris_uk
Posted 24 November 2008 - 03:52 PM
i dont know, but dont forget the sensors are different, or they are on my 2.2 they have different plugs.
#5 The Batman
Posted 24 November 2008 - 04:04 PM
i think i paid about that price when i was changing one of mine. it was a right pig of a job! i bought a proper lambda remover and that just rounded the thing off! then i got a big ass spanner on it, slipped and broke the wires when they join the sensor :lol:
#6 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 25 November 2008 - 12:55 PM
I think the difference between the sensors is the length of wire they come with If you buy a generic one you'll have to splice the wires, as it (prob) won't come with the correct plug on the end :)
#7 Toady
Toady
  • 713 posts
  • Interests:cars, mountain biking, skiing/snowboarding, anything adrenaline pumping!
Posted 25 November 2008 - 01:07 PM
and you cant solder the wires!
#8 siztenboots
Posted 25 November 2008 - 01:11 PM
is this 100%
#9 Oli
Oli
  • 250 posts
Posted 25 November 2008 - 02:06 PM
ive ordered a universal one off ebay. its coming tomorow. There is a thread i found in the useful thread collection explaining the process of changing it. Does anbody know how much of the diffuser and undertray has to be removed on the vxt to get to the lambda's? i will be taking it apart tonite so a heads up would make things a bit easier!
#10 siztenboots
Posted 25 November 2008 - 02:08 PM
you can reach in the engine bay from the passenger side to get to the main mixture sensor which is number 1, which matches the fault code you have. have you been getting poor mpg ?
in the picture below, see the blue plug, see the grey wire below, that goes to the sensor by the precat
Edited by siztenboots, 25 November 2008 - 02:10 PM.
#11 Oli
Oli
  • 250 posts
Posted 25 November 2008 - 02:19 PM
would it not easier to take the wheel off or take the diffuser off? i dont see how im gunna reach into there. especially if it gets fiddly - which it probaly will!!
#12 Oli
Oli
  • 250 posts
Posted 25 November 2008 - 02:23 PM
"you can reach in the engine bay from the passenger side to get to the main mixture sensor which is number 1, which matches the fault code you have. have you been getting poor mpg ?" i dont seem to have poor fuel consumption at all. infact it almost seems a bit better at the moment!
#13 Oli
Oli
  • 250 posts
Posted 03 December 2008 - 10:57 AM
Well what a bitch to get to!! had a look yesterday and it looks like the heat shield is in the way. Has anybody removed the lamda from their turbo? any tips?? cheers
#14 SteveA
SteveA
  • 9,159 posts
Posted 03 December 2008 - 12:00 PM
Yes, push the heat shield towards the pre-cat and get an adjustable spanner on it. If it won't come off easily it may be seazed. If this is the case you may need to remove the precat to get enough force to get it out (which is a nightmare)
#15 Toady
Toady
  • 713 posts
Posted 30 September 2009 - 01:12 PM
is this 100%
sorry to drag up old thread but, to answer the above yes it's true. I tried! Was then told by a sparky on site why but can't remember now, something to do with it being too pure silver wire or something?? had to use crimps!
