Gearbox Oil
13 replies to this topic
#1 M3VXT
M3VXT
  • 175 posts
Posted 16 December 2008 - 02:51 PM
I would like to know, which oil/grade is recommended by vauxhall for the VXT......How many litres will I need. I have seached but found so much conficting information on what people use. All I want to know is what vauxhall recommend and then I can choose from that. I guess there will be some oils which are great but I see alot of it is down to personal preference. So if anyone knows of good/bad ones that will help aswell. Any Help is great
Edited by M3VXT, 16 December 2008 - 02:51 PM.
#2 slindborg
Posted 16 December 2008 - 03:04 PM
do NOT and I really mean DO NOT use Silkolen/Fuchs Syn 5 75W90 Fully synth.... its ok when hot and in summer, but in the winter it makes the box an utter slag to live with. I've had "frozen box" (oohhh errrrr) 4 times already this month lol. I am considering either a straight 75W fully synth (more a motorcycle oil) or a MTF (such as redlines MTF, or AMSoil, or Royal Purple). From reading US threads on the matter they are all going back to Dexron III, which is odd as its a very old "design" of oil now a days
#3 M3VXT
M3VXT
  • 175 posts
Posted 16 December 2008 - 03:07 PM
I have been looking at using REDLINE D4 seems to fit the bill well. I have used syn5 in the past I agree it's a bit of a "tight box" when cold lol
#4 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 16 December 2008 - 04:51 PM
I have the Silkolen studd in and not had any issues with the box, minus 4 a few times and lives outside in the cold :D The worst I have experianced is a bit stiff to get into reverse once when car was frozen solid but 2nd attemp fine???? Maybe teh M32 box does not suffer from the same issues as much?
#5 M3VXT
M3VXT
  • 175 posts
Posted 16 December 2008 - 05:04 PM
Yeah not saying it wasn't usable just a bit tight first thing in the cold mornings.
Anyone got an opinion on this redline stuff below. Meets dexron III spec
REDLINE ATF D4
#6 slindborg
Posted 16 December 2008 - 06:12 PM
I'm having a chat with a transmission engineer tomorrow to seek his learned opinion :D
#7 M3VXT
M3VXT
  • 175 posts
Posted 16 December 2008 - 08:00 PM
Well I have had a closer look the amsoil MTL looks like that could be a good one :unsure: and comes recommend by a few other on here. Does turn out to be one of the more expensive £35 for 2.8ish litres, but not intending on changing it for a while, only drained it as I changed the clutch and flywheel. It would be good to hear what the transmission blokey says!!!
#8 Arno
Arno
  • 1,239 posts
Posted 16 December 2008 - 08:19 PM
Why not simply use the OEM Vauxhall stuff? Transmission Fluid Catalogue No. 19 40 768 Part No. 09 120 541 Quantity approx. 1.55L Bye, Arno.
#9 slindborg
Posted 16 December 2008 - 08:40 PM
Transmission Fluid
Part No. 09 120 541
I tried to get hold of some of the "proper" stuff and GM have stopped supplying it .... well the stealer I went to has anyway lol
2.25L ;)
#10 oakmere
oakmere
  • 2,143 posts
Posted 18 December 2008 - 11:55 AM
I have got the Amsol gear lube long life supplied by CMS and it has been fine and this year seems a little less tight that the standard stuff. Cheers Oakmere
#11 davep24
davep24
  • 353 posts
Posted 18 December 2008 - 03:04 PM
GM discontinued the dexron III stuff and replaced it with part number 93165290, cost £4.04 plus vat per litre. Used it for nearly a year now a had no problems
#12 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 18 December 2008 - 03:19 PM
Transmission Fluid
Part No. 09 120 541
2.25L ;)
says on my autodata cd the same things including 1.55L,
is it wrong about the amount then?
#13 slindborg
Posted 18 December 2008 - 03:41 PM
its a bit vauge... I'm sure I read on z22se about it properly though.
http://www.astraowne...e...9115&page=2
#14 jaylin
jaylin
  • 279 posts
Posted 21 December 2008 - 07:43 PM
Possibly relevent?:
I put in Amsoil. then run hot, then flushed and refilled with Amsoil to correct level, to be asured it was free from original oil.
The car had done 1Ok and by 16K the mainshaft/layshaft bearings were shot and second gear syncro/bulk ring damaged causing poor and then almost impossible selection of second gear at any temperature.
Result being gearbox overhauled...
Coincidence?
Unfortunately, after changing to this oil, a friend of mine who is a manual/auto gearbox repair specialist advised me he would have left the standard stuff in!
He then lead on to say the fully synthetic oil doesn't give as much protection.
Interesting you mention Dexron III, as he is now using this in his E46 M3 instead of the standard fully synthetic oil.
IMO after advice and the damage to my gearbox I would not use fully synthentic oil and stick with GM standard or a Dexron III equivilent.
Food for thought...
