- Car Jack -
20 replies to this topic
#1 Freedo
Freedo
  • 528 posts
Posted 01 January 2009 - 08:34 PM
As title says... What do you have? I don't really want to spend £80+ on a new racing type one.... Regards,
#2 techieboy
Posted 01 January 2009 - 09:06 PM
Drive onto a block of wood or a couple of bits of scaffold planks and you can use a regular trolley jack. I've invested in one of the racing trolley jacks and they're great - well worth it if you need to jack the car up frequently (which I do swapping sets of wheels on and off depending on weather for trackdays). You got the car for a song so surely there's something in the budget for a jack.....
#3 ianrm
ianrm
  • 11,097 posts
Posted 01 January 2009 - 09:07 PM
Taking the front wheels off a trolley jack lowers enough sometimes.
#4 mrbodger
mrbodger
  • 336 posts
Posted 02 January 2009 - 06:43 PM
I've been looking at trolley jacks, do I need to buy a racing one or will an ordinary (cheap) trolley jack be sufficient?
#5 Freedo
Freedo
  • 528 posts
Posted 02 January 2009 - 06:51 PM
Not sure if it's just mine (lowered on coilovers) or on standard vx's also but I've got 2 standard jacks and they still need to be another inch or so lower.
#6 smithers
smithers
  • 995 posts
Posted 02 January 2009 - 06:55 PM
my 2tonne halfords jack works just fine - vxt on std suspension. admittedly it has only a couple of mm clearance, so lowered would be a no no. about £30 I think it was. i would buy a racing jack if i could do it again though - for a few extra quidit is a lot less hassle. isn't rolling it up on wood etc a bit of a gamble though?
Edited by smithers, 02 January 2009 - 06:57 PM.
#7 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 02 January 2009 - 07:33 PM
:yeahthat:
I drive a wheel up onto my old brake discs. then jack up with halfords jack. The car weighs nowt so doesnt need daft priced jacks to lift. Use your head instead of your wallet.
Scott.
#8 DaveMax
DaveMax
  • 145 posts
Posted 02 January 2009 - 09:15 PM
Regards,
I have a cheap trolley jack (circa £20-£25) that will just fit under the VXT jacking point if I remove the circular black top section (whatever that is called). This is held on by a spring split pin that can be pulled out fairly easily with a pair of pliers. My VXT has Nitrons so it is lower than std, but the jack works fine.
Edited by DaveMax, 02 January 2009 - 09:16 PM.
#9 ianrm
ianrm
  • 11,097 posts
A bit of 4x2 about a foot long with one wheel on isn't going anywhere
#10 joebristolgym
joebristolgym
  • 150 posts
Posted 02 January 2009 - 09:48 PM
Found my cheap Halfords jack wouldn't quite go under my standard vx220 - however drove the rear wheels onto a bit of wood and the jack flew under. Don't see why this would be risky, the car isn't going to fall off the wood!
#11 smithers
smithers
  • 995 posts
Posted 03 January 2009 - 05:30 PM
good point well made! :lol:
not sure what size piece i had in mind!
#12 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 27 February 2010 - 10:56 PM
Anyone got a point as to where I can jack it FROM? I can't seem to find that diagram on here...
#13 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 27 February 2010 - 11:11 PM
I have a cheap halfrauds jack and like Davemax I have removed the swivel cup from the jack and it fits under fine chinky chinky Seb f if you look at the undertray there should be round stickers there indicating where the jacking points are chinky chinky
#14 Jameshs
Jameshs
  • 3,511 posts
Posted 27 February 2010 - 11:12 PM
the sill is a good place. Look under the car just inline with the back of the door and you should see a blue sticker. Thats a jacking point
#15 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
Posted 27 February 2010 - 11:25 PM
Cheers guys, hadn't looked yet and I am putting the new wheels on tomorrow! Thanks
#16 The Batman
Posted 28 February 2010 - 01:16 AM
LINK
#17 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
Posted 28 February 2010 - 10:22 AM
Awesome!
#18 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 01 March 2010 - 12:35 PM
Awesome!
Alternatively I have just used an old-school stylee (God did I just type stylee Posted Image ) scissor jack from my MG/Rover.
Yes it is not ideal, but is low enough to chuck it underneath and with the VX weighing less than the MG/Rover (which kicks both wheels up anyway irrespective of which jacking point you use on it) and the car doesn't move on it either.
Managed to change all the wheels over as well as to change the nearside TRE.
#19 d4nnyk
d4nnyk
  • 769 posts
Posted 01 March 2010 - 12:40 PM
I haven't brought one yet, but going to soon, entry level of 80mm and at £40, sounds good to me
ebay
EDIT: spelling
Edited by d4nnyk, 01 March 2010 - 12:40 PM.
#20 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 01 March 2010 - 12:43 PM
I have 2 low racing type jacks and 2 normal type ones - in the past drove onto wood to get jacks under but if your changing things regular - I was and the low jacks worth every penny. I can JUST get the low jack under the front now and is less than a mm from scraping the sill :P LOL DG
