Power Loss Under Hard Acceleration, Wierd...
Posted 02 January 2009 - 09:40 PM
Posted 02 January 2009 - 09:43 PM
Posted 02 January 2009 - 09:56 PM
Edited by Nev, 02 January 2009 - 09:57 PM.
Posted 02 January 2009 - 10:07 PM
Posted 02 January 2009 - 10:51 PM
Posted 03 January 2009 - 08:06 AM
Posted 03 January 2009 - 09:35 AM
My car was doing this just be for xmas turned out to be OXY sensor , one nearest to engine but they did try to sell me a new ECU first, my vx is a turbo so don`t know if an N/a would be diifferent, Good luck!!!!!!!!!!hello all
a little story for a cold friday night...
I had begun to notice during the past week , that the car "stuttered" under hardish accleration at high speed. I tried to ignore it, knowing that this is a problem that needs to take a back seat because I've got a few others to deal with first (haven't we all).
Just an hour ago, I was accelerating and all of a sudden the engine note changed, that car stuttered and the eml (engine management light- for noobs) light started flashing for about 20 seconds then it stayed on.
I was very worried. what the hell has happened to it? It sounded really rough, a bit like a subaru impreza actually, and power was greatly reduced.
when coming off the throttle, the engine sounded fine but when throttle was on, it juddered etc. I was wondering wether a hose had come loose, started to deform and constrict or that something more serious was the problem.
I nursed it back home and turned off the engine, not knowing whether I was going to hear it again. I logged onto this site and did a search, a very familiar story has already been told so I start to calm my nerves.
I've just been back out and restarted the car, the eml light was on, on ignition but went out and the car seems to idle fine...
the purpose of this story is to ask you knowlegeable ones on here, what I should do next.
I'm going to check all the hoses tomorrow but should I disconnect the MAF sensor?
Should I reset the ECU?
And has anyone else fixed whats caused this in the first place?
Also, thank god for this site, its such a good resource.
I'm off to bed now...
Posted 03 January 2009 - 09:46 AM
Hey Star
Is it the same issue as this?: http://www.vx220.org...s...3109&hl=obd
sounds pretty much exactly the same.. OBD II reading is the way forward mine came up with misfire cyl 1.
I took the coil pack out and it was dripping in water
Posted 03 January 2009 - 10:50 AM
Posted 03 January 2009 - 11:00 AM
Coul be water ingress
Sounds like mind did when it did that,
Posted 03 January 2009 - 11:45 AM
Posted 03 January 2009 - 12:46 PM
http://uk.youtube.co...h?v=7zZFi_Pd9FI
this was the coil pack that was dead and was misfiring on one of the cylinders.
Edited by chris_uk, 03 January 2009 - 12:46 PM.
Posted 03 January 2009 - 02:09 PM
Posted 03 January 2009 - 05:46 PM
Posted 03 January 2009 - 05:54 PM
Is there any clear and definite way to test the coil packs on the NA and VXT?
Posted 04 January 2009 - 12:51 PM
swap with a known good one. Thats what i did, not that.....
Posted 05 January 2009 - 10:57 AM
I tightened up three jubilee clips on the air intake pipe bit when I got to the one near the engine I tightened it and it snapped! I've yet to fit another one, although it seems to be on very tight already.
On top of that, I tried to very carefully, disconnect the DIS pack to check the plugs and broke the fekkin clip cos I was trying to gently move the tab with a screwdriver!!!!
Does anyone know where I can get a new clip? I looked at the part number here
http://www.speedster...td.)/index.html
and it looks like the whole loom will have to be bought!
I'm going to check the relays in the boot. Probably break them too...
Posted 03 April 2009 - 10:57 AM
Posted 03 April 2009 - 10:01 PM
