Piper Cams And Verniers
Posted 04 February 2009 - 04:08 PM
Posted 04 February 2009 - 04:16 PM
Posted 04 February 2009 - 10:50 PM
There is some confusion if they do work on the Z20 but they def work on the C20LET and they have the same cams as z20.
info:
http://www.astraowne...;highlight=cams
http://www.vauxhall-...ght, cams.html
Got to get my cambelt done so be rude not to if it works!
Posted 05 February 2009 - 11:59 AM
Posted 05 February 2009 - 12:03 PM
Excuse my ignorence but what are the advantages of a venier pully other that its lighter?
allows very accurate and small timing adjustments to the cam
Posted 05 February 2009 - 12:04 PM
More finite adjustment to the cam timing. Instead of advancing/retarding it with the OEM pulleys which might mean a 3 degrees or more (depending on how many teeth on the pulley) you can adjust it in much smaller increments. Or, something along those lines.
Posted 05 February 2009 - 12:41 PM
But how does that suit the teeth on the belt? If it has more/smaller teeth than how does it match with the belt?
Posted 05 February 2009 - 12:46 PM
Edited by techieboy, 05 February 2009 - 12:50 PM.
Posted 05 February 2009 - 01:05 PM
Posted 05 February 2009 - 01:11 PM
Stick with std VXR z20LEH cams - anyone know the spec of this cam? I do also assume the z20let and z20leh are the same cams??
Change to c20xe inlet cam and adj pulley - from looking at the links Paul put up the cam there is a statement that the x20xev inlet cam has 1mm more lift and roughly 20deg less duration than the standard z20let cam.
Regal inlet cam - The regal inlet cam has less lift than the x20vex cam but has the same duration as the standard z20let cam. (I was wrong on my last statement then, they are different lol)
Piper VXR cam change - details on the site - http://www.pipercams...rCamFrames.html
Courtenay Sport do a full set of cams via Stephan Klasen http://www.klasen-mo...;products_id=68
These cams where specially developed by us during long tests. They give a wide revrange up to 7500rpm and constant maximum power from 5500-7500rpm where with the standart cams the maximum power drops at 5500rpm. Especially the for turbos very important exhaustcam gives a good response for the turbo and less exhaustgas in the cylinder when new fresh air comes in. These cams are machined from blanks on a modern CNC-camgrinding machine and have a lift of 10.6mm. They can be fitted on standart camsettings, but you should use adjustable camgears if the cylinderhead was machined on the gasketside. With big Garrett-applications we measured 70HP more at 7000rpm compared to standard cams!!!
vmax also do a set again no data - http://www.vmax.de/
Guess the issue may be if I am going to start to really rev the engine its not just the cam change
If only lots of money and time were available
Posted 05 February 2009 - 01:40 PM
Posted 05 February 2009 - 01:55 PM
Might see what deal piper come up with on the cam & pulley!
Cost may also play its part (does most times lol) but def interested if cheap enough
Posted 05 February 2009 - 02:29 PM
Posted 05 February 2009 - 04:02 PM
yep, the theory is only swap the x20xev inlet cam, not the outletOn higher boosts the exhaust timing becomes very important on a LET engine!
Posted 06 February 2009 - 10:51 AM
Posted 06 February 2009 - 11:30 AM
But a site I used to find out about the how's and why's is....
http://www.max-boost...cams_C20LET.htm
Might be a usefull read for those looking into it.
Posted 03 April 2015 - 05:35 PM
Ok I exhume this topic because I need a pair of cam pulleys and it's not so easy it seems.
We've got an half ring behind the exhaust pulley that's used by the camshaft position sensor and the only manufacturer that offer this option is RnD, but this guy don't want to sell me these pulleys
So is it possible to use the pipercams pulley for example, do the ECU would work without the camshaft position sensor and do a remapping could sort an eventual problem ?
