Ly99
17 replies to this topic
#1 rsg
rsg
  • 3,306 posts
Posted 16 February 2009 - 09:12 PM
Got a few goodies through today from accross the pond B) :D
Supertech standard sized waisted stem valves with nitride coating
Supertech dual valve springs with titanium retainers
Currently porting and polishing a cylinder head, to fit with Comp cams stage 1 cams, 2.4 manifold and a D.I.Y. induction kit (yes I'm a cheapskate!)
I've spent the day removing the front clam and doing a few bits around the front of the car.
Main reason is to fit my new rad from the Elise parts group buy (cheers Joe chinky chinky )
Also wanted to repaint the front grill with satin black hammerite as it was looking quite rusty. The front Vee paint was chipping too as whoever painted it did so straight on top of the silver paint. I've gone from this
to this
Another job was to remove the heater box and clean the matrix and refit with the venair mod
Edited by rsg, 16 February 2009 - 09:14 PM.
#2 Exmantaa
Posted 17 February 2009 - 11:15 AM
What springs did you buy? The Supertech 76, 78 or 94 lb version??
#3 The Batman
Posted 17 February 2009 - 04:19 PM
how comes you didnt go for bigger wasted stem valves?
#4 rsg
rsg
  • 3,306 posts
Posted 17 February 2009 - 07:03 PM
94 lb version - same as GM racing dual spring set.
Coz i didnt want to have to get the valve seat reground (££s) and waisted stem valves make a much bigger difference than larger heads.
I can remember reading one of Vockys posts on z22se.co.uk that he thought the valve heads were big enough anyway.
#5 rsg
rsg
  • 3,306 posts
Posted 01 March 2009 - 09:05 PM
Bought a cam cover off ebay going cheap. Cleaned it all up using Betaclean and lots of elbow grease.
Sprayed with Black wrinkle paint and left to dry. Not had chance to fit it yet though
More valve pictures
Standard inlet on the left, supertech on the right
Same again but in the cylinder head
Exhaust gasket fitted to head showing how much the port can be opened up
Some of the casting that needs to be smoothed
Edited by rsg, 01 March 2009 - 09:05 PM.
#6 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 04 March 2009 - 09:24 PM
Wow - looks like those valves will make a massive difference to the flow thumbsup I read somewhere about leaving a step from the exhaust port, and not matching to the gasket; for the life of me I can't remember where now :rolleyes: Something about return pressure waves :unsure: (it was def the exhaust port, as I was intending to match mine to the gasket too)
#7 rsg
rsg
  • 3,306 posts
Posted 04 March 2009 - 09:28 PM
Yeah that was me (here)! and the general oppinion was that was for old yank V8s. I did what Vocky did on his Saab head ( chinky chinky Vocky)
Edited by rsg, 04 March 2009 - 09:30 PM.
#8 mandarinvx
mandarinvx
  • 12,621 posts
Posted 04 March 2009 - 09:33 PM
:lol:
#9 MrSimba
MrSimba
  • 5,197 posts
Posted 04 March 2009 - 10:14 PM
You look like you've been busy Rich thumbsup
#10 rsg
rsg
  • 3,306 posts
Posted 04 March 2009 - 10:37 PM
well my wallet has if nothing else :lol:
#11 rsg
rsg
  • 3,306 posts
Posted 31 July 2009 - 06:47 PM
Update from the last few months.
I've fitted an anodised fuel cap and surround (obviously).
My header seal was peeling in several places and during one particularly bad downpoor on the M5 water started dripping in all along the header rail :o so I bought the latest design Elise seal from Bell and Colvill (cheers Theolodian).
Took all of half and hour to fit and has made a differece to cabin noise. There is noticeable reduction in wind noise and when you shut the door the roof puffs up which proves the cabin is now very well sealed thumbsup
I've spent the past week giving my suspension a refresh. The cars coming up to 60k miles so I thought rather than waiting for parts to wear out I do it all in one shot. Bought some Eliseparts Track rod ends, Elise parts Tie rod upgrade kit and the Autobush Wishbone bush kit. I also bought 8x ball joints but these turned out to be First Line which don't fit. I couldnt be bothered to play Ball Joint Lottery so sent them back and bought 9x Elise parts ones (9x because I put the first one in the wrong way round :beat: )
The Tie rod kit went on ok but needed some slight adjustments to get it to fit properly. The inner bracket wasnt deep enough to cover rivet up to the subframe and allow the rose joint to fit. I spaced it out and used bolts to fix it rather than the rivets supplied. I'll get some photos up when I get chance.
Had the car geo'd today by Mike at Sports Car Services. Big thumbsup for the service. Driving the car back it feels so much tighter and there is absolutely no slack in the steering B) . I did check for play in my steering rack but it all seemed solid. All the little squeaks and rattles have gone and I imagine the car feels like it did when it left the factory.
The eliseparts kit recommends 4x 1.9mm washers to set the rear bump steer, but driving down a bumply road the rear moves around alot and doesnt feel as planted as it was so I think I might play around removing a couple of washers. If I cant get a setting I like the feel of a trip to Hofmanns bump steer rig might be in order
#12 mandarinvx
mandarinvx
  • 12,621 posts
Posted 01 August 2009 - 11:11 AM
Pics would be great mate thumbsup :)
#13 rsg
rsg
  • 3,306 posts
Posted 06 August 2009 - 07:54 PM
Right some pictures of the Eliseparts kit:
The first problem was I saw was the rod locking nut would foul on the subframe during full compression. The picture below was taken at full droop:
The mounting face of the subframe is not flat, where the original ball joint sits. I filed the sides of a washer flat so it would sit and added a couple of extra washers to space the rose joint further out:
With the damper removed I could jack the hub up and check there was enough clearance.
The second problem was the bracket supplied did not mount against the subframe when fitted with the rose joint, as it was still 5mm from the subframe. In the fitting instructions the bracket is riveted inplace once the subframe is drilled. I used some small M5 bolts and some spacers I had to enable the bracket to mount properly. I was going to get some wider brackets made up, but having spoken to Mike at Sports Car Services, when he did the geo, he said it was fine as it is. The Elise is exactly the same so I can t see how the brakcets would actually fit. In this picture you can just see the nuts used to fill the space:
This is how the outboard end of the rod connects to the hub. Between the rose joint and the conical spacer there are washers to adjust the amount of rear bumpsteer.
Still besides these small problems I still think this is a much better setup than standard (and its half the price of importing the Spitfire kit from the Dutch website or where its from) :)
#14 mandarinvx
mandarinvx
  • 12,621 posts
Posted 06 August 2009 - 08:20 PM
Cool, cheers mate - good to know it's worth the effort thumbsup Which kit did you order - as they list one for the S2 and one for the 111R/Toyota; and did they explain what the differences were :unsure: :)
#15 rsg
rsg
  • 3,306 posts
Posted 06 August 2009 - 08:24 PM
I ordered the Elise S2 kit. Its all to do with what rear hubs you have
#16 mandarinvx
mandarinvx
  • 12,621 posts
Posted 06 August 2009 - 08:31 PM
I thought it was the 111R that had similar hub carriers to the VX (as people have said in the past if you want to fit Lotus wheels and hubs you need to get wheels from a Toyota engined car) I might give them a call before ordering thumbsup
#17 rsg
rsg
  • 3,306 posts
Posted 06 August 2009 - 08:36 PM
Ah ok then
From the Elise parts website it looks ike you should get picture no 1 in the kit, that it pretty much what I made by filing the washer. You might want to ask about that too
#18 mandarinvx
mandarinvx
  • 12,621 posts
Posted 06 August 2009 - 08:46 PM
chinky chinky
