Sump Pan Bolt Torques
Posted 18 February 2009 - 07:29 PM
1, The bolts that hold the sump pan in place and the order they should be tightened?
2, The two bolts that hold the oil sender in place in the bottom of the sump pan?
I have a slightly dented sump pan - I have straightened and now need to refit.
Many thanks.
Posted 18 February 2009 - 07:53 PM
Does anyone know the torque settings for:
Many thanks.
basically the sump bolts are very low torque, so you should be able to feel when its right. I;ve seen lots of stories of LET/XE's having sump bolts snap so go careful
Posted 18 February 2009 - 08:27 PM
Many thanks.
1. It's all in the wrist - not very tight as slindborg says - tighten them all till the pan starts to bind on the gasket and then tighten opposing bolts.
2. dunno
Posted 18 February 2009 - 09:39 PM
Posted 19 February 2009 - 09:11 AM
What's the TIS???Tried the TIS?
Posted 19 February 2009 - 09:36 AM
