Scraping/grinding Noise On Throttle Lift-off?
Posted 21 February 2009 - 01:32 PM
Posted 21 February 2009 - 04:08 PM
Posted 21 February 2009 - 06:53 PM
Posted 21 February 2009 - 07:44 PM
Posted 21 February 2009 - 10:16 PM
Posted 21 February 2009 - 11:20 PM
My NA also does it when lifting off. It does it more when warm so I suspect something in gearbox. Oil level in box fine so probably some thingy in the clutch whose name escapes me ..... but will apparently be fine for ever.
Thrust bearing , I get it too sometimes but apparently its not anything to worry about , just anoying when all you want to hear is the exhaust burbling
Posted 21 February 2009 - 11:29 PM
Posted 21 February 2009 - 11:56 PM
does it sound like loose biscuits shaking about in a tin?
if so then TADTS... my (and most ive been in) N/A makes that kind of noise in 4th/5th when you lift off the throttle... even did it after new mounts, so I think its shunt in the gearbox
His is not an NA, but I have not noticed biscuit tin sounds as being normal. I dont know there are that many noises it makes a new one seem insignificant, a rattle here a knock there its all part of the fun.
