Suspected Turbo Problem
Posted 09 March 2004 - 04:24 PM
Posted 09 March 2004 - 04:30 PM
Posted 09 March 2004 - 04:34 PM
Posted 09 March 2004 - 05:18 PM
Posted 09 March 2004 - 05:21 PM
Posted 09 March 2004 - 06:10 PM
Posted 09 March 2004 - 06:15 PM
Posted 09 March 2004 - 06:24 PM
Posted 09 March 2004 - 06:39 PM
Posted 09 March 2004 - 09:55 PM
Posted 10 March 2004 - 09:48 PM
Posted 10 March 2004 - 10:19 PM
Posted 10 March 2004 - 10:23 PM
No he sold his sole to the devil and traded his beautiful silver vx for the red tarts car from footballers wives. A celebrity VX but the footballers wife didn't come with it!Is your new car you got in silver Andrew?
Posted 10 March 2004 - 10:32 PM
Posted 11 March 2004 - 08:43 AM
Posted 11 March 2004 - 09:10 AM
I had this last summer. It feels like you are doing a full throttle gear change, without the electronic trickery to stop the engine over-revving. The diagnostics showed a fault with the clutch switch, which was replaced and solved the problem.After a hard drive it goes, I have had a few over revving moments where it revs wildly when I change gear. I have switched the engine on and off and allowed the ECU to reset, and all has been well. I may try this next time when I have the flatspot problem.
It has happened a coupe of times in the last few months. I fiddled around with the clutch switch, checked the contacts, etc. and the problem went away. These switches are notorious for failing/causing problems on other cars apparently.
The first time it happened, the management light did not come on. You could only tell there was a problem by driving it. More recently, the management light came on. It went out immediately after pratting about with the clutch switch, and has not come on again since.
As for the lack of power above 4000 rpm, it could be a faulty AMM (Air mass meter). A failure can result in the engine running lean at higher revs, which may account for the symptoms in the first post. I've not had this problem, but bought a spare one, just in case - £118 at your friendly local Vauxhall dealer
Before modifying it, my car had a very small flat spot around 3000rpm, which I assumed was to do with emissions or drive by noise regs. Derestricting the airbox and fitting a Courtenay panel filter reduced this, and the AMD Stage 2 has replaced it with a huge dollop of torque
Posted 11 March 2004 - 10:09 AM
Posted 11 March 2004 - 10:16 AM
Posted 11 March 2004 - 02:07 PM
Posted 11 March 2004 - 02:16 PM
