Suspension Question / Problem
Posted 24 February 2009 - 04:14 PM
so after cleaning i pulled off the wheels and looked at the coilover height, on was 54mm from the bottom of the adjuster to the top of the twist plate the other just 53mm..
now i cant see this causing such a big difference once the wheels are on so i put it down to the surface it was on, not perfectly straight but not a cobbled road etc..
then i noticed a dint in the floating wishbone (top one) checked the other side and this had the same mark...
these are the pic
rear left
wishbone
above
rear right
wishbone
above
is this normal, both dints look to be almost identical and in the same place.
Posted 24 February 2009 - 05:00 PM
Posted 24 February 2009 - 05:01 PM
Posted 24 February 2009 - 05:05 PM
Posted 24 February 2009 - 05:08 PM
Posted 24 February 2009 - 05:14 PM
Posted 24 February 2009 - 05:16 PM
Edited by chris_uk, 24 February 2009 - 05:16 PM.
Posted 24 February 2009 - 05:56 PM
Posted 24 February 2009 - 05:59 PM
Edited by chris_uk, 24 February 2009 - 06:03 PM.
Posted 24 February 2009 - 06:09 PM
yea the car is lowered, but ive never heard them hit before.. and it doesnt look like there are mark on the subframe.
it was on quite a stiff setup aswell, ive made it softer now and i couldnt hear anything
im on gaz suspension if someone else wants to check it out
Look at the stain/mark which is right in line with your wishbones....
I'd say you are running to low, or the suspenders are to soft meaning it's bottoming out....
Edited by Garry.L, 24 February 2009 - 06:11 PM.
Posted 24 February 2009 - 06:12 PM
Posted 24 February 2009 - 06:14 PM
Posted 24 February 2009 - 06:18 PM
Stupidly expensive - best to phone round some breakers, tho make sure you ask them to cjheck for straightness firstdoes anyone know how much new ones are?
Posted 24 February 2009 - 06:20 PM
Posted 24 February 2009 - 11:03 PM
Posted 24 February 2009 - 11:23 PM
do you think id be ok to keep driving with it like this..
the arm itsseld isnt bent but jsut dented..
yes, it will be absolutly fine, mut have been like that for a while, judging by the photos.
i would just wait till a second hand set turn up.
Posted 25 February 2009 - 01:45 PM
Posted 25 February 2009 - 02:09 PM
and I know what I am talking about :
Posted 25 February 2009 - 02:11 PM
