Posted 25 February 2009 - 04:49 PM
Posted 25 February 2009 - 04:57 PM
Posted 25 February 2009 - 05:11 PM
Posted 25 February 2009 - 05:26 PM
Posted 26 February 2009 - 08:29 AM
Posted 26 February 2009 - 08:31 AM
Posted 26 February 2009 - 08:43 AM
Posted 26 February 2009 - 08:52 AM
vauxhall will remove them if they go faulty and the ecu can accept the revised software, also the usa ecotec 2.2 engines don't have them.Interesting part of the Wikipedia site on removing the EGR....
"In the past, a fair number of car owners disconnected their EGR systems in an attempt for better performance and some still do. The belief is either EGR reduces power output, causes a build-up in the intake manifold, or believe that the environmental impact of EGR outweighs the NOx emission reductions. Disconnecting an EGR system is usually as simple as unplugging an electrically operated valve or inserting a ball bearing into the vacuum line in a vacuum-operated EGR valve. In most modern engines, disabling the EGR system will cause the computer to display a check engine light. In almost all cases, a disabled EGR system will cause the car to fail an emissions test, and may cause the EGR passages in the cylinder head and intake manifold to become blocked with carbon deposits, necessitating extensive engine disassembly for cleaning."
Posted 26 February 2009 - 09:06 AM
Posted 26 February 2009 - 09:46 AM
Posted 26 February 2009 - 10:05 AM
ouch... i seem to be in way over my head here! (hogman) Throttle Bodies look uber expensive! ie. i haven't actually found a price for a kit yet without having to £call !!
i understand this EGR a bit better now, so are you saying that you could just unplug the connector and see a bit better performance regardless of the new mani?
is the 2.2 mani not compatible with the EGR on the NA? thats why you need a cheating device/not connect it?
the job is looking more desirable to do, having read reports of others and now oakmere taking around 5 hours etc, so should be within my capabilities! what would you say the most difficult part of the job is to do? and most risky? or is it fairly simple, just frustrating working at the back of the engine?
Cheers guys
Craggers
Posted 26 February 2009 - 10:25 AM
Posted 26 February 2009 - 10:50 AM
Posted 26 February 2009 - 01:54 PM
Posted 26 February 2009 - 03:09 PM
I will go to Courtney soon for a remap. Partly I want the rev limit raised and partly because I believe all/most of the extra power the mod frees up are held back because the ECU cannot 'trim up' enough fuel to match the extra airflow available.
Posted 27 February 2009 - 12:17 PM
Posted 21 March 2009 - 12:25 PM
Posted 21 March 2009 - 01:37 PM
