Balancer Shaft Removal
Posted 25 February 2009 - 09:30 PM
Posted 26 February 2009 - 08:12 AM
Posted 26 February 2009 - 09:06 AM
I searched and only found 2 topics on the subject.
Is it really necessary to pay the £89.95 from CS for the removal kit?
What do you need to do after removing the shaft?
Thanks,
You could buy the bits seperately, save a few quid maybe.
Her is a (bad) pic of mine after removal:
edit - I have the instructions in a PDF, PM me your email and will send it over (cant copy document contents)
Also, check the bearing caps for wear. Mine were fine
Edited by cheeky_chops, 26 February 2009 - 09:18 AM.
Posted 26 February 2009 - 10:12 AM
Posted 26 February 2009 - 10:57 AM
Posted 26 February 2009 - 12:04 PM
Posted 26 February 2009 - 12:21 PM
Can I ask why you would want to remove the balancer shaft? Does it give more power, better response or some other reason?
Cheers
Kevin
Posted 26 February 2009 - 12:30 PM
Cheers
Kevin
Do the balancer shafts not counter the fact that this is an inherently poorly balanced engine (originally based on a 1.6)? In which case would it not be detrimental to the longevity of the bottom end unless it was properly balanced at the same time as removing the balancer shafts i.e. the kind of thing cnrandall is doing on his race europa project?
Elise Trophy Europa blog
Edited by ollster, 26 February 2009 - 12:32 PM.
Posted 26 February 2009 - 01:05 PM
Posted 26 February 2009 - 02:10 PM
Posted 26 February 2009 - 03:25 PM
The engine was due to be back from balancing last Saturday but as we had made the decision to source another crank to cut up for testing purposes this deadline had to be pushed back. The crank, which was destined for the chop, arrived with Steve late on Monday, which meant he couldn't do the work until Tuesday. The testing exercise on the crank was worthwhile though as we found that, even with a piston/rod combo some 300grams lighter than stock, there was a 300gram deficit on each crank counter balance. At 7000rpm this equates to a 2 ton bending load on the crank between each cylinder! Looking back through the history of this engine, which is the latest in GM's line of "Family 2" engines, you will find that the block itself dates back to the seventies. The first of these engines had an 8-valve OHC head and a capacity of 1.6 litres, it's our assumption that on raising the capacity of the engine, GM didn't go the extra mile to change the block to accommodate the extra counterbalance required for a larger 86mm (2 litre) stroke and associated heavier pistons. On these current generation engines you will find a dual-mass flywheel, a crank ladder and also dual counter rotating balancer shafts - all signs of GM fighting to control an inherent engine vibration. On the positive side, the sturdy block (which weighs 38.5kg on it's own, that's 18.5 heavier than a Honda K-20 block!) is regarded as virtually bullet proof by the Vauxhall engine experts so stands a good chance of holding the crank in place regardless of the large bending loads placed on it by the imbalance. To cure this problem properly I'm intending to go down two routes, firstly to use tungsten inserts to add mass in every counter weight and secondly to start the search for lighter pistons to reduce the amount of counter balance necessary. These are both modifications requiring careful thought and research so will be left for later in the year and, in the mean time, I will have to hope that the block holds onto the crank firmly enough and I'll keep the engine rev's down to sensible levels.
Edited by ollster, 26 February 2009 - 03:30 PM.
Posted 04 May 2009 - 01:03 PM
Cheers! Now for the other side of the question, why is it worth doing? What if you are thinking of supercharging?I removed the balancer shafts from my 2.2 engine a couple of years ago, it's a myth that the engine becomes lumpy and unbalanced.
I had the bottom end balanced a few months ago and the only thing which required rebalancing was the lightened flywheel, the crank was spot on. I do however have steel rods and forged pistons.
Posted 04 May 2009 - 01:17 PM
Posted 04 May 2009 - 01:33 PM
Edited by joe_589, 04 May 2009 - 01:38 PM.
Posted 04 May 2009 - 01:43 PM
Posted 04 May 2009 - 01:47 PM
Posted 04 May 2009 - 01:53 PM
Posted 04 May 2009 - 04:39 PM
Thanks for the feedback on deleting balance shafts.
If your at the Midlands Meet next month there are a few of us there now with the balancer shafts taken out, your more than welcome to come out in mine and see what you think
Good to meet you yesterday as well, sounds like you've quite a project on your hands!
Edited by MrSimba, 04 May 2009 - 04:39 PM.
Posted 04 May 2009 - 06:20 PM
the balancer delete would remove 4 Kg, then the lightened flywheel some more, so you should be under the weight of a standard vx nowit does, i did it
think mine weighs under a standard vx 2,2 now
Posted 04 May 2009 - 06:22 PM
plus the other bits and bobs removed
sound proofing is so so heavy
Edited by joe_589, 04 May 2009 - 06:25 PM.
