Turbo Oil Return Pipe Part No
7 replies to this topic
#1 Jive
Jive
  • 361 posts
Posted 31 March 2009 - 11:35 AM
Hi I have a small leak from the Oil return Pipe from the turbo, Item No 1 in the image below.
When I upgraded to the Astra VXR Turbo/Manifold I had to twist the flange (with the gasket labeled No 2 on it) through 90 degrees to get it to align with the new manifold. At the time i was nervous about creating a leak but i was gonna have to buy a new pipe otherwise so twisted it anyhow.
It twisted on the flange joint well and leak tested fine but last week i got a whiff of oil burning and after a little rummage around found some residue left on the pipe.
I assume I need the Pipe and Gasket off of the Astra VXR but need the part number Does Anyone know/have it?
Edited by Jive, 31 March 2009 - 11:37 AM.
#2 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 31 March 2009 - 12:19 PM
Just got a new one to fit with the replacement turbo - got the wrapper still so will get you the number ;) I have my oil one which I do not think is leaking and welcome to have it (was my turbo core leaking) Also have a spare gasket ;) New ones are about £50 :(:(:(:( DG 1st replace gasket 2nd all oil breather pipes not blocked 3rd new pipe :( 4th new turbo lol :(:(:(:( Hope this helps Oh and yes its the astra vxr pipe I have angled ;)
#3 siztenboots
Posted 31 March 2009 - 01:16 PM
will need the same info please
#4 Jive
Jive
  • 361 posts
Posted 31 March 2009 - 05:01 PM
Thanks for the offer. My local stealers claim to have the correct part number and I had already told them to get it on order for me before reading your post. All the same if you can confirm the correct part number I will feel a lot better. If its the same as the stealers order then at least I know I havent handed over my money for no reason and I think siztenboots will be happy :) If its not then I need to go slap the stealers for being.... well stealers.
#5 ChrisW
ChrisW
  • 65 posts
Posted 31 March 2009 - 05:41 PM
Astra VXR oil return pipe is 55351646 & the gasket is 55564222 + 2 seals for the banjo bolt 11017691 The pipe retails at £34.15 + vat
Edited by ChrisW, 31 March 2009 - 05:46 PM.
#6 Whiteboy
Whiteboy
  • 6,950 posts
Posted 31 March 2009 - 06:54 PM
Vauxhall have done a recall on astra vxr turbos and most have still have leaks!!!
#7 Jive
Jive
  • 361 posts
Posted 01 April 2009 - 07:11 AM
what is leaking on the recalls? The same pipe? I bought the turbo off courtenay's last summer, should i be concerned?
Anyhow looks like i have the right parts on order, i hate paying retail prices though. :(
thanks for the offer duncan
#8 siztenboots
Posted 01 April 2009 - 09:42 AM
presumably , if jive has his sorted, duncan is your oil return pipe still going spare then ?
