Turbo Vent And Rear Spoiler Removal
6 replies to this topic
#1 D4VE
D4VE
  • 28 posts
Posted 02 April 2009 - 10:33 AM
Hi, How do you remove the turbo side air vent? and also the rear spoiler? I had a quick search but couldn't see anything. I'm getting them painted hopefully next week if I can get them off! Thanks
#2 VIX
VIX
  • 9,497 posts
Posted 02 April 2009 - 11:36 AM
IIRC the spoiler has three bolts attached to it so should have three nuts to undo inside the boot. There might also be some sealant or double-sided tape to keep the water out. chinky chinky
#3 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 02 April 2009 - 12:08 PM
there are a couple of hex bolts on the outside of the vents. Take out and you can (iirc) get a spanner in to the nut. There is a 99.999999% chance the nut bolt will be rusted solid and you cant get to the bolt head :beat: You can pull the vents out as they have rubber washers either side of the nuts and are open backed (U). Cut the washers off the nuts, then put back with thinner rubber washers if poss or as is (they will rattle a little bit)
#4 D4VE
D4VE
  • 28 posts
Posted 02 April 2009 - 01:11 PM
Thank you gents chinky chinky
Wish me luck!
#5 Code Monkey
Code Monkey
    forum whore
  • 2,425 posts
Posted 02 April 2009 - 03:57 PM
NAing a Turbo? Don't do it :D
#6 JG
JG
  • 13,612 posts
Posted 02 April 2009 - 04:13 PM
Do it thumbsup chinky chinky
#7 182ian
182ian
  • 426 posts
Posted 02 April 2009 - 05:08 PM
NAing a Turbo?
Don't do it :D
I gather by the hoping to get them painted next week he is putting them back on the car! :rolleyes:
