Uprated Fuel Pump
15 replies to this topic
#1 VXR 43
VXR 43
  • 594 posts
Posted 02 April 2009 - 06:38 PM
I am in the process of fitting a new leh lump and I am trying to cover some areas that will need sorting before I can go over 300bhp. For the fuel system I have noticed that quite a few are going the route of swirl pot and extra pump but as I have the anti surge tank I think I might be able to get away with an uprated pump as a direct replacment. Klasen-motors have a walbro pump on there web site. Are there any more manufacturers on the market or is that it? If so does anyone know the part num of the one they use? Cheers PS A MASSIVE thank you to Danger7 for helping me sort out the new unit from Vmax. Top Top bloke!
Edited by VXR 43, 02 April 2009 - 06:40 PM.
#2 FLD
Posted 02 April 2009 - 06:47 PM
I'm idly looking at this one. From what I've seen some people put an additional in-line pump in series with the original (I dont like this). Some have used the original to feed a swirl pot and an external pump (I dont like this either). You can modify the pump housing sump piece to just be a fuel pick up and then use a large external pump (like an aeromotive). I'm currently drying to figure out which walbro pump is the one to look at as they are reasonably dimensionaly similar. As such you should be able to just plug and play. If you find out what walbro pump does what post it up here.
#3 VXR 43
VXR 43
  • 594 posts
Posted 02 April 2009 - 07:04 PM
I am guessing it is similar to this one but I will need to find out before I purchase...
http://www.shop.indi...48c7c562dd15303
#4 FLD
Posted 02 April 2009 - 07:08 PM
Yep, those are the ones I've been looking at. theres also one that flows over 300 lph. Have a look at escort cosworth pumps as they have a very similar set up.
#5 cnrandall
cnrandall
  • 943 posts
Posted 02 April 2009 - 07:22 PM
Get yourself a separate swirl pot and a bosch high-flow pump. I can advise on parts if you like.
#6 VXR 43
VXR 43
  • 594 posts
Posted 02 April 2009 - 07:27 PM
I would like to go for a straight replacement instead of using the swirl pot route if its possible. After a few searches on the AOC and MIG forums it looks like quite a few have gone down the route of uprating with a walbro replacement. Cheers
#7 techieboy
Posted 02 April 2009 - 07:42 PM
Check with Courtenays for the gory detail but the Walbro drop-in replacement isn't ideal as it doesn't have quite the same return setup that the OEM pump has. Not sure it has the headroom needed for 300+bhp either. Just going through the pain myself at the moment. I've got the long range tank aswell but am having to go with a secondary pump and swirl pot setup hence the reason it's at Pro Alloy at the moment, whilst they design a plug and play kit compatible with tubbys and NA/SC's. Unfortunately Pro Alloy also do a version of the tank with an integrated swirl pot that will take a motorsport pump direct at an extra £40 which would have solved all of the problems.
#8 Exmantaa
Posted 02 April 2009 - 08:17 PM
What about the eliseparts pump?
http://www.elisepart...php?product=620
#9 techieboy
Posted 02 April 2009 - 08:46 PM
I think it's exactly the same Walbro pump. Note, they say they can rebuild the assembly with a further uprated pump which might be a better option but still not sure if it will support whatever this return problem is. At the time, I kind of vaguely understood Jon's explanation and he sort of vaguely understood the explanation he got from Germany about why it wasn't ideal. He sent a pump off to Glencoe the UK fuel pump specialists to see if they could come up with a drop-in solution but nothing as yet.
#10 MAXR
MAXR
  • 2,719 posts
Posted 03 April 2009 - 06:03 AM
I'm having the Pro Alloy tank with intergrated swirl pot & motorsport pump fitted at the moment by Courtenay's...It's not a cheap fix!
#11 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 03 April 2009 - 08:43 AM
Seen your pump yesterday Max :) car is running also ;) I gave up on the in tank solution due to the issues stated - Regal say they can upgrade it if you send them the pump but not sure of specs Swirl pot works with inline is more than fine - only thing is you have 2 pumps rather than 1 lol The std pump is more than upto keeping that swirl pot full :D and certainly had not problems on the roller over 2 days If I had time I would have poss taken the tank out and got it to wayne to mod but the Bosch 044 pump I used with swirl pot and all conections was sub £230 so prob the cheap option also especially with such a good pump ;)
#12 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 03 April 2009 - 08:44 AM
iirc the walbro wont fit - there is plenty of info on seloc and no solution (last time i looked) except the external swirl and inline bosch jobbie
edit: just found this http://forums.seloc....d=196137&page=1
edit again: seems walboro 255 model 342 fits, though this maybe only the toyota engined tanks? :unsure:
http://www.monkeytun...c...?f=4&t=1137
Edited by cheeky_chops, 03 April 2009 - 09:22 AM.
#13 alanoo
alanoo
  • 1,324 posts
Posted 03 April 2009 - 09:24 AM
Ah seen it on their crazy Audi Elise, but didn't knew they are now selling it
#14 cnrandall
cnrandall
  • 943 posts
Posted 04 April 2009 - 07:56 AM
It's up to you but you will likely till get fuel surge on track with a drop in pump. Extra cost of a reliable fueling setup far out weighs the risk of your engine going lean.
#15 alanoo
alanoo
  • 1,324 posts
Posted 04 April 2009 - 08:18 AM
Yep, but another thing I don't like is having the swirl pot fed by the OE (high) pressure pump. In an ideal word I'd like a setup with an intank LOW pressure pump feeding the swirl pot then a Bosch one... I have not seen this kind of setup yet
#16 VXR 43
VXR 43
  • 594 posts
Posted 04 April 2009 - 09:59 AM
Even with the Pro Alloy anti surge tank?
