Part of it is working out-of-the-box
I think the circuit overlay function will be no problem as well, as its data is coming from the units own GPS.
I want to create a VX220 dash overlay with a layout similar to the STACK unit, when I get the RPM signal input to work, should be no problem, but....
The part that I can't get to work is the RPM input from the CanBus. None of the supplied values seem to work. So far I've tried GM_RPM1, GM_RPM2, GM_RPM3, LOT_Engine_Spd and with different Baud rates 500KBit and 1Mbit.
There are so many parameters which have to be correct to get it working:
Name:
Units:
Scale:
Offset:
Minimum:
Maximum:
ID (hex):
DLC:
Start bit:
Data type:
Std/Xtd:
Data format (Intel/Motorola):
Too many options to try them all. Anyone done this before?
If the RPM signal is working, next step could be Throttle Position, Coolant Temperature, Intake Air Temperature, Battery Voltage and more...
Edited by manus, 08 April 2009 - 07:12 PM.
