16' Front Wheels?
Posted 12 April 2009 - 04:33 PM
Posted 12 April 2009 - 04:43 PM
Posted 12 April 2009 - 04:44 PM
Posted 12 April 2009 - 04:51 PM
Quite a few people have run the Astra H SXi wheels, as they are similar to the tubby ones, need quite a big spacer and new wheel bolts tho
thanks lads, any idea what size spacer? and why new bolts??
Posted 12 April 2009 - 05:07 PM
You need longer bolts as the spacer moves the wheel further away from the hub where the bolts locate (by 10mm in this case)
Posted 12 April 2009 - 05:13 PM
For the spacer you need to be aiming for a fitted offset of around 20~26ET to arrive at this figure find out what the donor wheels offset is (ET figure) and subtract the ideal ET (above) to get the spacer width.Quite a few people have run the Astra H SXi wheels, as they are similar to the tubby ones, need quite a big spacer and new wheel bolts tho
If say the astra wheels (example not necessarily correct!) is 38ET subtracting 26 gives a difference of 12 for the ideal spacer width.
Vauxhall 5 stud spec Spacers from Eibach go from 5mm to 16mm and then 20mm (from memory) so you'll need the 16mm one.
this will give a fitted ET on a ET38 wheel of ET22
so could be ok if the wheel is no more than 7" width.
Longer bolts needed as the bolt has to pass through wheel and spacer to screw into the hub, if using a 16mm spacer look for 45mm length bolts M12x1.5 (usually plenty on fleabay).
Some hub centric spacers are bolted to the hub using short bolts, the original whel bolts are used to attach the wheel to the spacer, these are steel and add a lot of wieght where the eibach ones are alloy.
Edited by Mac-Cos, 12 April 2009 - 05:14 PM.
Posted 12 April 2009 - 05:35 PM
good thread, steve crisp recomends a 6mm spacer with standard bolts on the astra sxi wheels.Looks like a 10mm spacer
do you think that would be ok?? im not the best with wheel offsets!!
Posted 12 April 2009 - 06:10 PM
as topic really, are there any front wheels off the likes of astra, vectra, corsa that are 16' and the same offset that will go onto a vx220 without any problems??(so i can put sticky rubber on)
im thinking just the fronts so i dont have to buy a full set of wheels(just for trackdays!!)
thanks for any info!
You're just going to put sticky rubber on the fronts and leave normal road tyres on the rear for trackdays or have I just misread/misunderstood?
Edited by Sticky, 12 April 2009 - 06:10 PM.
Posted 12 April 2009 - 06:30 PM
ill have track rubber on front on spare wheels and put track rubber on rear when i do trackdays, come back and change them overas topic really, are there any front wheels off the likes of astra, vectra, corsa that are 16' and the same offset that will go onto a vx220 without any problems??(so i can put sticky rubber on)
Posted 12 April 2009 - 06:35 PM
Oh I see. Too many eggs today have made brain turn to chocolate obviously
Hope to see you at a TD or two later in the year then.
Sticky
Posted 12 April 2009 - 08:34 PM
Posted 12 April 2009 - 09:29 PM
Or just buy an old set of NA/Tubby wheels for peanuts - that will give you a second set of rears for your project.
And a pair of fronts to put plant pots on
i think a set of fronts will do for now, i work in a vx dealership so i can change the rears for nowt
Posted 16 April 2009 - 08:27 PM
Posted 17 April 2009 - 07:39 AM
anyone else used the astra sxi alloys???? any probs with them??
I have Astra 16" rims, not mounted yet (i'm testing GY GS D3 195/45 17 on original turbo rims).
You need 11mm spacer to reach the original offset.
Posted 17 April 2009 - 05:19 PM
11mm? iv heard some people using 6mm????
Posted 19 April 2009 - 04:33 PM
SXi rims and a 6mm spacer have been fine for me for a lot of miles and a long time. The standard wheel-bolts are just fine too.
Steve
Posted 27 April 2009 - 02:57 PM
Posted 27 April 2009 - 03:04 PM
Posted 29 April 2009 - 03:14 PM
