Brake Problem
Posted 10 May 2009 - 04:48 PM
Posted 10 May 2009 - 04:51 PM
Posted 10 May 2009 - 04:54 PM
I dont know,Im new to the VX scene...what were the problems and how could I find this out please?Do you know if you've had the servo hose recall done
Its a 2004 model.
Posted 10 May 2009 - 05:09 PM
Edited by siztenboots, 10 May 2009 - 05:10 PM.
Posted 10 May 2009 - 05:53 PM
Posted 11 May 2009 - 03:52 PM
I got in the car this morning,drove it to work and back home and the brakes are fine....WEIRD!!I have this problem too at the moment. Having my vaacum hose done Wednesday as it's deteriorated at the end. Didn't have the recall done either.
Also having brake fluid changed.
Since the fun with my brakes started my abs light comes on alot too. Putting a switch in this week too though
Gonna change the master cylinder anyway just for piece of mind.
Posted 11 May 2009 - 04:02 PM
Posted 11 May 2009 - 08:51 PM
Yes thats right,I took a mate to show him how good it handles 5 minsbefore it happened. Should I bleed and refill with dot 5.1 or maybe a silicone fluid??you'll find it mainly happens when it you've been braking a lot/hard and the the system gets very hot
Would this help? I dont know!
Posted 11 May 2009 - 09:01 PM
no dont change fluid types its so much hassle that its not worth doing imo.
I think your right changing the cylinder as leaks dont manifest as fluid leaking out but rather air leaking in and that sounds alot like whats happened and by pressing the pedal more than once you were able to build pressure.
imo get a mechanic to look it over rather than ppl on the internet speculating.
best of luck!
Posted 12 May 2009 - 06:01 AM
Posted 14 June 2009 - 09:12 AM
Ive been driving around in my Turbo all day with no problems whatsoever then all of a sudden I pressed the brake pedal down and it went all the way to the floor before the brakes worked. I thought maybe I was just being a bit paranoid because when I tried again the pedal was firm again.
Two minutes later I applied the brake again and down it went,pressed again and firm...mmmm. I then drove home and parked it up with engine runing and applied them again and down it went again,pressed brake once more and pedal was firm.
Ive checked and fluid level is fine,no pipes off or leaking that I could see either!!
Im thinking maybe Master Cylinder.
All advice will be appreciated and much needed,
Thanks,
Danny
You have just described exactly what happened to me and my VX yesterday. I got the AA out to check the discs pads fluids and to see if there are any leaks and he very confidently said there is a leak in the brake master cylinder as there were no other problems. Pumping the pedal once or twice creates the pressure again and he said there was normal pressure at the pads/discs. He also showed me the location of the cylinder and so it looks a relatively striaghtforward job.
the problem
Did you change your cylinder and has it solved the problem?
Also if you did change it where did you get the cylinder from and what was the cost?
