Stuck Window Mechanism
Posted 17 May 2009 - 05:32 PM
Posted 17 May 2009 - 07:18 PM
Posted 17 May 2009 - 08:22 PM
Posted 17 May 2009 - 10:24 PM
Posted 18 May 2009 - 10:34 AM
mines doing exactly the same going half way up......i'll be trying what you did soon as i get the car back
Thanks,
I will try some lubrication.
Dave
Posted 18 May 2009 - 10:36 AM
It could be that the sliders at each end could be out of alignment or dislocated. Can you move your window backwards and forwards in the door - ie towards the front and back of the car?
In my case, the front runner top mount was bent and needed bending back to stop the movement of the window. Whilst apart it is worth regreasing the runners to prevent any tight spots.
Good luck!
When I am looking at the window mechanism there is maybe 1" of space for travel at the front roller and maybe 3" at the rear roller. Does this sound the same as your when the window is up?
I thought there should be more travel at the front roller and possibly my runners had shifted??
Thanks
Posted 18 May 2009 - 11:11 AM
Hope this helps
Phil
Edited by pjohn151, 18 May 2009 - 11:12 AM.
