Edited by SteveA, 01 June 2009 - 10:15 AM.
Taking The Hit
Posted 01 June 2009 - 10:04 AM
Posted 01 June 2009 - 02:16 PM
Posted 01 June 2009 - 02:32 PM
Sounds good. That was a HUGE spread on the progressive rates!Looking at the graphs i've finally decided (with help and advice from Nitron) to go for the standard Nitron Rates for VXT (375F & 475R) This is the same as it was at 90% compression on the progressive springs. I was always happy with the std springs when pushed hard but didn't like the original roll induced when cornering lightly. These linear springs should sort that out
Posted 01 June 2009 - 05:35 PM
Posted 01 June 2009 - 05:40 PM
Posted 01 June 2009 - 07:04 PM
Sorry totally off topic but,
Mr Randall sir, what's happening with your Europa, read your build blog, watched you win at Silverstone & saw the pictures from Brands. Is it going to fight another day?
It is very much alive and kicking and as soon as I have ten mins I'll do a big blog update. Unfortunately with the repairs and the huge amount of real work we have on at Hofmann's I've neglected to keep the blog up to date. We are back on the dyno @ TDI this Thursday to check the engine and get it running on sequential ignition, then next week we should be testing at Snett prior to the race the following weekend. Along with repairs I've been making some of my planned mods to improve performance too, including new brake calipers with no ABS, rose jointed wishbones and a reduction of about 20kg (although that still leaves me 20kg overweight!).
Posted 01 June 2009 - 07:05 PM
Posted 01 June 2009 - 07:39 PM
Posted 01 June 2009 - 07:50 PM
Posted 01 June 2009 - 07:56 PM
Posted 01 June 2009 - 08:05 PM
I have to say, that graph looks quite sensible
Unfortunately Nitron don't run their tests down to the very slow speeds (which is the interesting bit TBO) as it takes an age but from the data you can see, Sachs aren't too far adrift. Would be interested to drive a car with a set as I havent yet.
You're welcome to have a go in mine.
Posted 01 June 2009 - 08:08 PM
So do you think the rates I've opted for are OK or would you suggest going stiffer? I was originally looking at 475F 600R but Nitron suggested going softer as the damping was significantly less than their 1 ways.
BTW - if you are at Cadwell Park on the 10th you are welcome to have a go.
Edited by SteveA, 01 June 2009 - 08:11 PM.
Posted 01 June 2009 - 08:15 PM
Posted 01 June 2009 - 08:25 PM
Posted 01 June 2009 - 08:48 PM
Posted 02 June 2009 - 06:39 AM
Nitron run WAY too much rebound in their standard set-ups, which is one of the things that's different in the 'randy' spec valving that I've developed. Conventionally, most road cars will run a circa 2:1 rebound to bump ratio and more and more you will see race cars running nearer 1:1 which is what I run at the Medium/Fast damper velocities. You will find that what you can 'feel' as a driver is the 0-50mm/s range of the damper and from that graph you can tell very little about what the damper is doing.
Anyway... If you keep hold of the Sachs then I would suggest the max rate you will get from Eibach in a 2" spring will be 550lb and I would put a 400lb front with that. If you upgrade then I'm more than happy to chat through with you the different spring rate and valving options we do.
One thing to remember, even if the Sachs do produce the right sort of graphs on the dyno they will still have limiting factors because of their small body size. At a basic level, what a damper does is convert stored energy from the spring into heat and with the smaller body dampers you are limited by the quantity of oil they can hold and the piston size.
Edited by cnrandall, 02 June 2009 - 06:40 AM.
Posted 02 June 2009 - 07:12 AM
Posted 02 June 2009 - 07:56 AM
Posted 02 June 2009 - 09:51 AM
Posted 02 June 2009 - 10:28 AM
How do you like those spring rates on bumpy roads? I am considering GAZ Golds, but I just don't believe that 425/475 is enough of a split considering how different the front and rear axle weights are. (I know that it doesn't directly translate, but still.)I'm on 400/550 and the roll is vastly reduced (thanks Chris!) If I decide to go Nitron, I will probably go for higher rates again. I think 375/475 is a bit low, especially on the rear. Thanks to Chris, I have learnt that a proportionally higher rear rate than the standard helps reduce understeer. From memory mine is approx "+70%" on the front and "+100%" on the rear when compared to OEM.
