Problem it fixes
This is a fix for symptoms which are a result of a lack of servo pressure, this includes:
- Lack of pedal travel
- Hard pedal feel at the bottom of pedal travel
- Extra effort required to achieve the same amount of braking
The above symptoms occur in particular following sustained wide open throttle acceleration and then immediate braking. Normal braking will usually return with repeated presses of the pedal or with time as the vacuum is replensihed.
What I think the problem is
The basic setup is that the brake servo is powered via a takeoff on the inlet manifold, as the throttle opens the pressure in the manifold drops and sucks air through the servo hose creating a vacuum. A one way valve in the hose in the engine bay prevents air travelling from the engine side to the servo side, thus preserving a volume of vacuum both in the servo and in the hose. At a standstill there is -0.8 bar of vacuum pressure, as the throttle opens this diminishes down to as little as -0.15bar. The servo in theory is able to retain enough vacuum for 3 presses of the brakes before it needs to be "topped up".
What actually happens in my experience (and it looks like a lot of others) is that under hard acceleration insufficient vacuum is retained by the servo for full servo assistance when you get on the brakes quickly afterwards and repeatedly.
How this fixes things
It simply connects in line on the main servo hose, allowing a substantial "reserve" of vacuum to be built up and held behind an inbuilt valve, regardless of what the servo is doing and what is happening with the pressure in the inlet manifold.
I have placed it in the space behind the sill on the driver's side, just where the servo hose passes through. It only requires one cut of the hose and mounting the canister, which I did on the end of the sill section.
I've been out for a long drive tonight and it seems much much better. Not once could I provoke the car into having a dead pedal, rather the pedal actually felt very consistent, even much better than when I didn't appreciate a particular problem. Braking power just doesn't seem to tail off, I like it
I believe Randy has done similar on his race car, also using another one way valve. However I'm inclined to think that isn't necessary as with two valves as it is, a vacuum gauge does not show the vacuum diminishing of its own accord.
I bought mine from a company in the US called Jegs for about $30.
Edited by Muncher, 18 June 2009 - 09:27 PM.
