P1171 On Supercharged Vx - Saga Continues
Posted 19 June 2009 - 06:25 PM
Posted 19 June 2009 - 06:43 PM
Might be worth checking to see whether your MAP sensor is properly seated on the supercharger body but can't help with the other error, I'm afraid.
Posted 19 June 2009 - 06:53 PM
Edited by PaulCP, 19 June 2009 - 06:54 PM.
Posted 19 June 2009 - 07:37 PM
Give Jon at Courtenays a call.
There's a fix for the fans (P1171 code) which he did on mine last week. Involves putting in a thermostatic switch rather than them being controlled by the ECU which also means they can be programmed to come in sooner than the 106 degrees.
Fans...fans...don't you mean fan?
I only have one fitted.
Posted 19 June 2009 - 08:08 PM
the proally charge cooler system fits two fans
Posted 20 June 2009 - 07:18 AM
Posted 20 June 2009 - 07:55 AM
I have the cool running thermostat - not sure if I have the water wetter too. My car generally runs cooler, around the 79-84 degree mark, but still shoots up to 100+ when stuck in traffic. I've just got a ScanGauge so I can turn the fan on. The thermostatic swich (or even a manual one) is probably a much cheaper solution although the ScanGauge can do other stuff like clearing codes.How easy is the thermostatic switch, my car gets hot quite quickly and am thinking of fitting a cool running thermostat as a simple solution. I am also going to add some water wetter to the system. Good ideas?
Martin s
Posted 20 June 2009 - 10:31 AM
Posted 20 June 2009 - 10:38 AM
Martin s
Not a bad idea Steve. I have a code reader which can pick up running data but don't think it is as sophisticated as the scangauge.
Interestingly enough Jon explained that the fact that the ECU switched the fan(s) on at 106 degrees was a bit of a cock up by Vauxhall. (some of us always thought it was a bit late). I think the point was that they used the Astra G setup which does have 2 fans, one which the ECU switches on at 98 degrees (ish) with the 2nd coming on at 106 degrees. Since the VX in original spec only has 1 fan the ECU control mapping picks up the latter temp to switch the fan on.
Not had chance to rest mine out yet but hopefully will do so this weekend but for track work the fans coming on earlier will be no bad thing
Edited by PaulCP, 20 June 2009 - 10:40 AM.
Posted 20 June 2009 - 10:59 AM
Posted 07 June 2011 - 10:08 AM
Posted 08 June 2011 - 02:15 PM
Posted 10 March 2014 - 10:07 AM
Bump...
Getting P1171 every now and then when warm, but no dash light, only fault via scangauge and fan on...
Is there any clear fault here? Can't really see much info above..
Posted 12 March 2014 - 06:03 PM
Could be tired fuel pump, I had it till I swapped my pump. The map also has a flat spot around 2250rpm which may also cause it (I believe later maps have solved this)
Posted 12 March 2014 - 06:09 PM
1171 historicly reported on:
- Fuel pump power low or fuel hose pressure leak. - Crack in exhaust manifold. - Injector plug not connected well - Alternator defect.
Take your pick
Posted 12 March 2014 - 07:15 PM
Cheers guys
Since posting this, and thinking about it some more, I had a cracked manifold when I got this code before, so I guess that feasable again... Will take a close look at weekend. Car has ticked over 80,000 so fuel pump feasible aswell.
Did a mammoth run in it last weekend and think the code popped up three times, but hasn't re-occured since..
