Confused About Tires....
Posted 08 July 2009 - 06:13 AM
Posted 08 July 2009 - 06:40 AM
205/50 R16 gives a slightly bigger rolling radius so fills the arch better. Extra width no problem for handling. Diameter 61.14 cm.
205/45 R16 gives a slightly smaller rolling radius so may look a bit small unless car well lowered. Diameter 59.09 cm.
Pic below is 205/50 R16 and very low (110mm ride height). Car being raised today as I am fed up of scraping it (second pic - also gives an idea of what a 205 looks like in the arch).
As for tyres - Kumho KU31 will do everything you want. The 205/50 R16 is more available and cheaper than the 195/50 R16
For rear, just keep standard 225/45 R17.
Posted 08 July 2009 - 06:43 AM
did try that height and i agree far to low
Posted 08 July 2009 - 02:23 PM
Posted 08 July 2009 - 02:42 PM
195/50 R16 is the 'right' size - same as an Exige or VXR. Diameter 60.14 cm
205/50 R16 will give the closest rolling radius to the 175/55 R17 of the original brigstones so the best option for the std ABS
Posted 08 July 2009 - 03:57 PM
Would a 205/55 R16 go too far the other way? ie rolling radius greater than the optimum of the originals?
Posted 08 July 2009 - 06:08 PM
Posted 08 July 2009 - 07:01 PM
23mm smaller is preferred, if you go for 195/50/16.So 13mm smaller diameter is better than 8mm larger? And if so why?
In tyre sizes of course
If it's good enough for a factory VXR and Elise then it's good enough for a VX. Maybe expect ABS issues.
I currently have KU31 205/45/16xl and no problems except a touch more arch gap than with larger diameter tyres. Meh.
Edited by Ouchie, 08 July 2009 - 07:01 PM.
Posted 08 July 2009 - 07:15 PM
Edited by Ouchie, 08 July 2009 - 07:16 PM.
Posted 08 July 2009 - 07:16 PM
Posted 08 July 2009 - 07:26 PM
Except the VXR, S2 Elise & Exige all have the 4 channel ABS rather than the 2 channel on the NA & VXT.
So would any of these:
205...55...16...632...+8
195...55...16...621...-3
205...50...16...611...-13
not be better than 195 50 16 given they are closer to the standard diameter.
I currently have standard wheels on my turbo but I am looking to change to TD's and trying to work out the best tyre sizes without introducing ABS problems.
Posted 08 July 2009 - 07:45 PM
I think that the issue there is finding tires actually made in some of these sizes.If it's good enough for a factory VXR and Elise then it's good enough for a VX. Maybe expect ABS issues.
Posted 08 July 2009 - 07:52 PM
Edited by goodeg, 08 July 2009 - 07:53 PM.
Posted 09 July 2009 - 04:27 AM
Oooh, and Nankangs!R888's & A048's are available in 205 55 16
T1R's & KU31's are available in 205 50 16
T1R's are available in 195 55 16
By available I mean listed on the Camskill website, I am unsure of stock.
Cor, those T1R's are a bit cheaper than the 175/55-17's! (which are listed as not available of course)
Has no one tried 195/55-16's?
Posted 09 July 2009 - 08:21 PM
I'd guess taller sidewall profiles would be just about the last thing you want to do with T1R's. The 50 profile was squidgy enough and can't imagine it'll be any better with a 55 profile.
Posted 09 July 2009 - 08:32 PM
