http://cgi.ebay.co.u...INE...:1|294:50
Should this be ok/fit?
I've a couple of questions as to how to perform the test itself on the VX
1. I've read that you need to hold the throttle open whilst turning the engine - will the fly by wire throttle on the VX actually open fully if the engine hasn't actually fired?
2. What's the easiest way to disable the injectors - is there a fuse or connector which is simple to pull?
Thanks in advance.
