Fault Code P0420
7 replies to this topic
#1 redvts
redvts
  • 1,472 posts
Posted 28 July 2009 - 04:21 PM
my scangauge came today, its really good, anyway i bought it because my check engine light was on, the code as you can see in the title is P0420, searched through old posts but couldn't find a definite answer as to what this means, can anyone help????
#2 chris_uk
Posted 28 July 2009 - 04:25 PM
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
full list
http://www.z22se.co.....php?f=3&t=3980
Edited by chris_uk, 28 July 2009 - 04:31 PM.
#3 Pooh Bear
Pooh Bear
  • 986 posts
  • Interests:Honey
In the instructions to the Scangauge it simply says to "google the trouble code" with the make of vehicle ie Vauxhall followed by P040. Give it a try as few results are thrown up... thumbsup edit: with the answer Chris uk has given :lol:
Edited by Penny, 28 July 2009 - 04:30 PM.
#4 redvts
redvts
  • 1,472 posts
Posted 28 July 2009 - 04:34 PM
tried that but doesnt point to anything specifically, cat knackered, one of the two lambda sensors is goosed or the egr valve is no good
#5 chris_uk
Posted 28 July 2009 - 04:40 PM
P1404 is the EGR fault, thats what i got anyway, im not saying it wont be that but id look at the 2 lambda sensors first. if you local to anyone ask to swap them and see if they get the fault using your lambda, and see if your fault clear using theirs.
#6 redvts
redvts
  • 1,472 posts
Posted 29 July 2009 - 08:19 AM
how hard are the lambda sensors to get at, do u need both rear underplates off?
#7 aron916
aron916
  • 2,055 posts
Posted 29 July 2009 - 08:25 AM
I get this code every now and again since getting my 200cell cat! On the scangauge, just scan for the code and then clear it...light goes out!
#8 redvts
redvts
  • 1,472 posts
Posted 29 July 2009 - 08:29 AM
yeah i cleared the fault last night but mine is a standard cat so there must be something up, on saying that ive driven about 40 miles since and it hasnt came back on
