Bodyshell Material?
14 replies to this topic
#1 Toady
Toady
  • 713 posts
  • Interests:cars, mountain biking, skiing/snowboarding, anything adrenaline pumping!
Posted 21 August 2009 - 01:46 PM
I was having a discusion with someone the other day and they thought the body shell was made of a plastic resin style stuff? I thought it was made of fibre glass? Whose wrong??? :tumble:
#2 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 21 August 2009 - 01:47 PM
Them
#3 dannynewport
dannynewport
  • 787 posts
  • Interests:Cars obviously. Train in MMA/Japanese Jiu Jitsu (More traditional style of BJJ), previously Karate, Ninjitsu & Krav Maga.
Posted 21 August 2009 - 01:48 PM
Both of you......the bodywork is made of paper mache!
:groupjump:
#4 techieboy
Posted 21 August 2009 - 01:49 PM
GRP (glass reinforced platic) isn't it? Though I guess the gelcoat was a resin initially.
#5 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 21 August 2009 - 01:54 PM
It's not your normal fibreglass construction tho It uses a cheaper method where the fibres are compressed in a mold, which means far less resin is used - but also means the fibreglass isn't as strong *this is only what I've been told in the past btw
#6 Yellow_or_black?
Yellow_or_black?
  • 12,905 posts
Posted 21 August 2009 - 02:08 PM
I was told that it's not fibreglass - that's a common misconception. Was told that it's layers of bonded stuff - fibres with gubbins; whereas fibreglass is - quelle surprise - just glass fibres. ETA: unless you were using 'fibreglass' to refer to FRP/GRP?
Edited by Yellow_or_black?, 21 August 2009 - 02:11 PM.
#7 fraser
fraser
  • 411 posts
Posted 21 August 2009 - 02:33 PM
i thought the gel coat was put into the mould then pre preg fibre glass was presssed onto the back then compressed to remove the air bubbles. Thats the way i've made glass fibre panels in the past Edit to say: pre preg- fibre glass with a bonding agent/resin already mixed in, can be in matts or sprayed on
Edited by fraser, 21 August 2009 - 02:35 PM.
#8 Winstar
Winstar
  • 4,264 posts
Posted 21 August 2009 - 02:40 PM
I think it's the same method used as for the S2 elise body panels where the panels are injection moulded glass reinforced plastic which are then bonded together to form the clamshells.
#9 rsg
rsg
  • 3,306 posts
Posted 21 August 2009 - 02:43 PM
:yeahthat:
most peoples impression of glass fibre is the chopped-strand matt type
#10 FLD
Posted 21 August 2009 - 03:22 PM
Both on the money! It is odd stuff neither really fibreglass or plastic. Its a process pioneered by renault where the fibres (of some type) are pressed in a closed mould (moulded both sides) then I believe a molten plastic is injected from one side. Its a poor quality plastic so very brittle hence the need for fibres. Where this does benefit is the cost of production with low labour rates and reliability of shape (every panel fits equally badly!).
#11 siztenboots
Posted 21 August 2009 - 04:22 PM
all wrong , its made from these
#12 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 21 August 2009 - 04:25 PM
yes but made with french crackers :yeahthat: ........... :groupjump:
#13 Boss VX
Boss VX
  • 644 posts
Posted 21 August 2009 - 06:32 PM
Im pretty sure its fibre glass with a gentle sprinkle of water giving a nice bubbly texture :P Freeking bubbles :angry:
#14 hairy
hairy
    Moonlander
  • 6,053 posts
Posted 21 April 2018 - 08:44 PM
Enlightening
#15 navx
navx
  • 369 posts
Posted 21 April 2018 - 09:29 PM
Where is Jon when you need him?
